Aluminum Extrusions For Bulb Seals - where to look??
mrekim
I want to add a bulb seal to the bottom of my slides to get a better seal when the slides are closed. The wiper seal doesn't do well.
I've found all kinds of bulb seals, but I have yet to find something to insert them into. I realize that I could probably get an aluminum L bracket and attempt to glue a seal to it, but I'd prefer something that was more serviceable.
Is there some place that I can look to find a bulb seal AND an aluminum strip that will hold the seal?
5 REPLIES 5
DrewE
Although intended for a different purpose entirely, maybe either this (wider) or this (narrower) extrusion would work with some seal you found.
SoundGuy
Search McMaster Carr.
2012 Silverado 1500 Crew Cab
mrekim
Just a hollow round tube. Most slides have them on the top and sides. Here's a photo of one with a t slot mount:
Happy_Prospecto
I hate to ask, but what in the world is a "Bulb Seal"?
Kevin
Retired, Fulltime RV'er, 1999.5 F350 4X4 CC Diesel Flatbed
2007 Alpenlite Defender Toyhauler, 2019 Polaris Ranger
Bob, the Yorkie Terrier helping me prospect til the money runs out
mrekim
Or if I end up with just a D shaped bulb seal and an a piece of aluminum angle then what adhesive can be used to bond the two?
