ANDERSEN LEVELERS ?
Oasisbob
These Andersen trailer levelers were mentioned in a thread recently. Checked them out online. Anyone using these and how do you like them? Says it can raise your trailer up to four inch's. Clever design. Any trouble comming off of them? My HTT is light and have used lego type blocks for years but they do slide on some surfaces and do not always guess correctly as to how many are needed. Any thoughts?
Oasis Bob
Wonderful wife 3 of 4 kids at home. 1 proudly serving in USAF
2018 Ford Explorer
2001 Bantam Trail Lite B-19
HAPPY TRAILS:)
17 REPLIES 17
Kevinwa
mogman wrote:
The wheels on my trailer are fairly close together, so I had to cut off approx. 2-3" off the thin end on one of the levelers so it would fit. They work great!
Now why didn't I think of this? The close axles is the exact reason that I rarely use mine. I guess I have an afternoon project.
mogman
'15 Ford Transit 250, 3.5 ecoboost, 3:73 ls
'12 Lance 1685
martipr
Muddydogs wrote:
martipr wrote:
Muddydogs wrote:
They work great though I wish I would have purchased the taller one's, I think they are around 6" tall, as sometimes the 4" ones just aren't enough. My trailer is a lot more stable when I use them and set the chock type blocks with a rubber mallet under the levelers, they seem to help take out the tire wiggle.
As far as I can find the levelers only come in one size 4". Andersen also makes a "Rapid Jack" which is similar to the leveler but somewhat higher. Looks like it is also longer so fitting it between the tires might be a problem.
I would swear that when I purchased mine there was a 6" version but maybe I was looking at the Rapid Jack and didn't know any better at the time? I looked around the internet trying to prove you wrong only to figure out that I'm wrong. Guess there's a first time for everything.
Yeah, I was also wrong one time. I have a set of the levers and love them. I also bought one of the Rapid Jacks but have not used it. I haven' checked to see if it is longer than the levelers and right I am stove up with a bad foot so can't go to the trailer to check
Old Navy Chief (AOC) Retired Aircraft Mechanic/Inspector
2007 29' 27FBV Trail Bay V Series
2015 Dodge Ram 2500 Crew Cab 6.7 Cummins Diesel
Reese Strait-Line Dual Cam Hitch
Muddydogs
2015 Eclipse Iconic Toy Hauler made by Eclipse Manufacturing which is a pile of junk. If you want to know more just ask and I'll tell you about cracked frames, loose tin, walls falling off, bad holding tanks and very poor customer service.
martipr
xzyHollyxyz
Adding a giant bubble level to the mix truly makes it a one-man job. (or one woman...) I LOVE them.
2015 Fun Finder 189FDS
2013 Nissan Frontier Crew Cab SV 4x4
Rustycamperpant
Love mine, should add some sort of board on sandy soil because they seem to sink. No problems otherwise. My wife watches the level and tells me when to stop. Much better than stacking things for level.
2009 Ford Expedition EB, 3.73, Equal-i-zer
2015 KZ Sportsman Showstopper 301BH
Dave_and_Sue
I use them and they really are a one man job.I mounted my large level on the drivers side front of the 5 er.I can see it and know when to stop as the bubble moves to level,or just a little high on the slide side as it tips that way when we put the slide out.they are well worth the price of admission.:B
2011 Ram 3500 Dually Mega Cab
2016 Chaparral 370FL
OutdoorPhotogra
I have an old popup that is cranky if it isn't level (pun intended). I wish I had bought Anderson's years ago. Much easier and quicker to get level than blocks or boards. I'm only dealing with one axle so if you have dual axles it will be more work.
2008 Rockwood Signature Ultralite 5th Wheel
F-250 6.2 Gasser
Former PUP camper (Rockwood Popup Freedom 1980)
Muddydogs
A set is for 1 tire its 2 pieces, a leveler and a chock that supports the leveler once the tire is on it. Double axle trailer will require 2 sets.
Here is what you get with 1 set.http://www.amazon.com/Andersen-Mfg-3604-Andersen-3604-Leveler/dp/B001GC2LVM
Oasisbob
Each wheel takes two pieces right? So you guys are raising each axle right? To you buy two sets or ? Can't figure how many pieces come in a set. Think I may give em a try.
Oasis Bob
2018 Ford Explorer
HAPPY TRAILS:)
DaYooper
I ordered a set and used them once and found them a bit difficult to get the level right on, of course this was in a loose sandy soil so that may have been part of the problem. I haven't used them since.
Maybe adding a level for side to side that is visible while I back up will help. My wife didn't seem to like using my level on the side of the trailer, like their videos show online.
Steve
SE Michigan
IAFF #2289
2014 Shasta Phoenix 32RE 5er
Husky 16K W Hitch
2005 Dodge 2500 CTD QC
4x4, Auto, 3.73
Muddydogs
I usually roll up on mine all the way with the wife watching the tires and telling me when to stop so I don't fall off the blocks. Wife then walks around to the levels and tells me when to stop as I pull down the blocks and the trailer levels out. If I'm by myself I just eyeball the trailer as I pull on the blocks and get out and check a couple times.
dhust
When you put them in, and start backing up on them, what is your setup to know when you are level? I can't see my level and back up at the same time.
