Any specific time to replace Batteries?
PyrateSilly
I know you should replace tires between 5 to 7 yrs, definitely before the 10 yr mark.
So does anyone change their rigs batteries by a certain time? Ours are about 5 or 6 yrs old now. We live full time in the RV and they are used constantly. Would it be just better to get them tested or test them ourselves? Have not seen the question asked before and was wondering. I see all kinds of info on how but not if there is a when.
Abigail and Christine having fun in a 1993 Monaco Crown Royale Signature Series 40ft 300hp RV.
19 REPLIES 19
MEXICOWANDERER
Landscatter?
May through October daytime temps in the Antelope Valley, eats batteries chemically. Acid is thermally incredibly temperamental. Identical batteries, identical float a flooded high antimony battery at 50c day and night may last 3 years, while the other battery maintained at 10c will last 15 years.
PyrateSilly
Ok, it looks like I am thinking along the right line in changing out the batteries. They are about 5 or 6 years old and over the last year or so the chassis battery doesn't seem to be holding that good of a charge. We have been mostly hooked up at one spot for awhile (job) but now we are about to go cross country and more so I am right in thinking that we are needing to just replace them all before we leave at the end of the month.
EDIT:
Last year at this time we went to Vegas. Starting the coach to come home we realized that the alternator was not charging the battery. The only thing charging the chassis battery was the 20 yr old 100 watt solar panel. With nothing running (ie no lights or ac) we were able to keep the charge at about 12 or so just in order to make it home. We made it all the way back to Lancaster, CA just before the sun went down. About 25 miles away the sun started to go down and you could see the charge start to drop. My other half rebuilt the alternator and now it all works like it should but I had a feeling that the batteries got a little down from that and needed to be changed out.
pianotuna
Nomad II
Nomad II
ktmrfs,
For marine jars 20% is the figure to aim at. i.e. they should always be 80% or higher state of charge. I got around that by having 7 in two banks--which gave me 140 amp-hours of "safe" discharge and it ran large inverters with heavy loads as if they were no trouble at all.
I did get tired of laying in the snow to check electrolyte levels, so when they finally began to fail after 9 years I replaced them with used telecom jars.
Regards, Don
ktmrfs
pianotuna wrote:
The deeper the discharge the shorter the life.
The longer between full 100% recharges the shorter the life.
Add solar charging and life span may improve dramatically.
good quick summary and excellent advice.
I'll add that most RV user's won't ever come close to being limited by the rated cycle life on a good 6V GC or real 12V deep discharge. Don't discharge GC below about 25 percent SOC, 12V below 50 percent.
True GC deep discharge are good for over 500 cycles to very deep discharge, 12V trojan deep discharge similar life but only to 50 percent. How many of us will ever discharge that many times to those levels?
But the key is to get them charged back up to a TRUE 100 percent full charge within a few days or week at the longest. watching water level, equalizing when needed.
Now if you have a marine battery, I believe cycle life is considerably less. they still have thinner plates for starting current and being a combo battery, likely lower cycle life.
2011 Keystone Outback 295RE
wa8yxm
I replace on an As Needed basis.. I can't see replacing 'em till they need replacing . NOTE. Exception. on a trailer the battery is a safety device and Id' say 7 years tops but on a Motor home... Well for starters I have two sets of batteries.. No safety issues if one dies.
pianotuna
Nomad II
Nomad II
Regards, Don
ktmrfs
Gjac wrote:
It really depends on how you maintain them. My two Sam's Club 6v GC batteries are 10 years old and I dry camp 95 percent of the time. I usually don't stay more than 3-4 days in anyone spot and have minimal 12v requirements so they may be at 70 or 80 percent SOC. Once maybe twice a year I stay for a week and they are at 50 percent SOC. I always charge to full within a week. Also equalize and desulfate several time a year. My Walmart starting battery was just replaced and was 10 years old also, I charged it along with my house batteries but it was a sealed battery so I could not equalize it. My first set were Trojan 105's which only lasted 4 years because I did not know at the time how to maintain them. I never got more than about 4 years out of my cars because the just get charged by the alternator. If you fulltime your 12v requirements will be much higher.
good care as you mentioned equals long life. On a good GC, keep the water level above the plates, charge fully after use, equalize occasionally and you will get long life. Trojan GC are good for 500 + discharges to 25 percent SOC. Been there, done that and haven't hit the 500+ cycles, but came close and batteries lasted 14 years. and discharging to only 50 percent will give close to 1000 cycles. well beyond what most any camper will see.
Gjac
time2roll
5thwheeleroldma
I replace my batteries, if they are 4+ yrs old, before the next long RV trip. I'm 79 yrs old and have been RVing for 20yrs; I just hate the hassle of having a dead battery out in some lonesome, no name town. Yeah, I do carry a jump starter, but still---
fitznj
I change my batteries when they start to have problems holding a charge.
This means that I get approx 4/5 years out of a set of batteries; I boon-dock
a lot with 300W of solar, so the batteries do get a work out but I keep an eye out on the voltage and make sure I don't draw them down.
Gerry
SCVJeff
Got 7 years out of my U2200 Interstates and probably could have nursed 3 more out.
Jeff - WA6EQU
'06 Itasca Meridian 34H, CAT C7/350
jerseyjim
My experience: no matter what brand i buy....be it "top of the line" Interstate...or a WalMart/Sams Club....I average 3 years.
1 12V to start the engine and 2 6V for the coach. You will know when they fail. Or start to fail.
So....I go for the price...not the brand.
stickdog
Car truck trailer 5-6 years after 5 years it seems to be a **** shoot. I've had them last 7 years but I wouldn't want to be in the middle of nowhere when they die.
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
โ€œA good traveler has no fixed plans, and is not intent on arriving.โ€ Lao Tzu
