Atwood 8500 series furnace bench test on high limit switch
JBarca
Nomad II
Nomad II
Furnace: Atwood Hydroflame 8520-IV DC Installed in late 2003.
I am doing a total restore on a wet 16 year old camper. I am at the point of servicing the furnace and have a question concerning testing the high side (over temp), of the high limit switch. The furnace is out of the camper, on a bench test setup, been cleaned up, gas valve replaced due to failing a pressure leak test, gas burner and heat exchanged inspected and are in good shape. By the looks of inside the heat exchanger and the burner screen being in such good shape, this furnace has not had a lot of run hours. The control board works as it should and the system now is in good running condition.
The question is, what method have you used, or know of, to confirm the “high side” of the high temp limit switch opens when it should? The Atwood service manuals do not talk to testing the high side, only if the switch fails to make continuity and is stuck open.
I have run two 40 minute continuous burn tests, taking various temperature checks around the furnace. With the setup I am using, the system will stabilize and come to equilibrium, running it longer does not gain much more internal temp.
My only question I have now before installing it back in the camper, is there a test used on how to force the system to confirm the high limit switch will open on an over temp? I have tried blocking the duct ports to raise the cabinet temperature, and while the system does increase some, it will not trip the over temp limit switch to shut down the gas burner. The duct ports where close to only approx. 20% open and it still would not trip the high temp limit. That said, the air temp at the limit switch was not hot enough most likely to trip the switch as I had a remote thermometer measuring the air temp at the high temp switch throughout the testing. The way I am doing the bench test may be partly why I cannot get the temperature hot enough to trip the limit.
At this point, the only idea I can come up with, is to pull the switch out of the unit and test it against a known temperature hot plate and see it opens up in the range of 190 deg F. That is doable with what I have to work with, but that is a lot of parts to take out to do this. Figured I would ask here first if someone has been through this before.
I have all kinds of pics and data sheets I can share if that will help, but it still comes down to, how is the high limit switch tested for hi limit, or is it not tested as they have not failed in that manner? It may be, I am trying to go above and beyond what normal furnace testing does.
Here is the bench setup, doing the testing.
The temp probe measuring the air temp at the hi limit switch.
The 6 temp. check points during testing.
1= Exhaust port, outside surface temp.
2= Heat exchanger surface temp at discharge.
3= Heat exchanger surface temp at end of gas burner.
4= Outside cabinet temp, above gas burner.
5= Furnace exit duct temp.
6= Hi limit switch senor area air temp.
Any help, greatly appreciated.
Thanks
John
2005 Ford F350 Super Duty, 4x4; 6.8L V10 with 4.10 RA, 21,000 GCWR, 11,000 GVWR, upgraded 2 1/2" Towbeast Receiver. Hitched with a 1,700# Reese HP WD, HP Dual Cam to a 2004 Sunline Solaris T310R travel trailer.
27 REPLIES 27
JBarca
Nomad II
Nomad II
Boundless2281 wrote:
Okay thank you. That's what I was afraid of. I did that and nothing happened. Verified 13+ volts to the positive and negative lead. No noise or anything from the furnace. I am going to check all the connections, but it seems like I may be buying a dinosaur board to replace mine.
Atwood had several control vintages of this furnace, the prior version used a thermal timing relay to run the fan and fan delay. The PC board, in this case only ran the gas valve, ignition, and flame sense circuit.
The next generation of controls did away with the timing relay and added the fan control to the PC board, which then controlled that fan and the gas valve, ignition, and flame sense.
Does your furnace have the thermal timing relay?
See the timing relay here; it is on the right end of the blower housing.
Here is the newer vintage with the fan control on the PC board—no thermal timing relay. A PC wire plug is on the front of the PC board; a blue wire, the T stat run signal, was added and is part of the fan control. The T stat run signal on the older thermal timing relay received the T stat signal.
This PC board has fan control on it. The black relay on the PC board in this pic is for the fan motor (the red wire is the fan motor hot wire, and the blue next to it is incoming 12-volt power for the fan motor). The round coil igniter also has a red wire but different insulation and goes to the electrode.
Some checks, and this assumes you have a 12.5 DC power or higher coming to the furnace.
If yours has the timing relay, they have been known to go bad over time. If you connect the two blue wires within a short period, the blower should run; if the blower will not run, either the motor is bad (less likely) or the thermal timing relay is bad (more likely). Check the fan power wires and see if it is getting power; if there is no power, then the relay is bad.
If you have no timing relay and twist the two blue wires, the fan should run after a few seconds as the PC board controls the fan motor. Check the fan motor power wire coming out of the PC board to see if the board is sending incoming DC voltage to the motor. If the board is sending power, then the motor has issues. If the board is not sending voltage, the board has issues.
Hope this helps
John
Boundless2281
trailrider
Connect the blue wires together to run the furnace.
2020 Chevrolet Silverado 3500HD GAS!!!
1978 Chevrolet Silverado K20 4x4
2007 Komfort 277TS
2020 Sherco 300 SEF Factory
2018 Honda Rancher TRX420FA6
2017 Montesa 4RT260
2021 Honda CRF450X
Boundless2281
Hello,
I know this is an old post, but I have the exact same furnace and need to bench test it. I am unsure what to do with the blue thermostat wires. I applied 12V to the positive and negative wires, but I am not sure what to do with the 2 thermostat wires. Do I need to connect them together? Or do they get supplied with 12V? They are both blue, does the polarity matter if I am supposed to be connecting them to 12V??
Thank you.
dougrainer
Zero(0) IS the smallest square bit. I was thinking of the No 1 that is used on some Canadian built door cabinet latches. Doug
larry_cad
dougrainer wrote:
Dusty R wrote:
That switch should never need to open. If it does there is not enough air moving through/over the furnace.
They open and close all the time. OEM furnace ductwork installs NEVER match the correct volume of air required to run the furnace without the Limit occasionally tripping. Also the RV'er will block off some floor ducts to get more heat or air to some areas of the RV. That will also cause the Limit system to trip. YES, it would be nice if the Ductwork was installed to meet the Minimum requirements to prevent Limit switch tripping. I can ALWAYS make both Furnace and Roof AC ductwork many times more efficient, but unless under warranty, the customer will not want to pay for a check out and making it to best operation. Rarely do I get a complaint about Ductwork under warranty. They just figure that is the way it is. Doug
Great information. Thanks Doug
Today is my personal best for most consecutive days alive.
Our Travel Blog
dougrainer
BFL13 wrote:
I only ever heard them called Robertson "up here". I suppose that is changing with younger people, don't know. Square Drive new to me until today.
I am 66 years old and have been in the RV industry for 50 years. Never heard them called Robertson until about 15 years ago on an RV forum. Doug
Hi Doug have same short cycling issue with my rv furnace high temp limit cycing.  if I keep the outside air door open it will run all day. outside and return air ducts are not restricted, curious if installing an additional heat duct under cabinet would fix air flow and exchanger cooling.
hi, you are  responding to a post that's 3 years old and Doug (unfortunately) hasn't been on here since the new forum was implemented. I suggest you post your question in a new topic to get responses.
JBarca
Nomad II
Nomad II
dougrainer wrote:
The actual Square drive bit I use for that limit switch is No 1. Doug
PS, in a pinch you can use a small needlenose Vise Grip pliers. Hard to do, but they usually grip the outer round part of the screw.
H'mm, that is odd. I tried my no. 1 bits and it would not fit. I used the mini Vise Grip method on the OD like you said and I'm ordering a few no. 0 bits for the next time.
No. 2 square head screws are all over the inside of the camper. Seems outside, 1/4" hex head is more prevalent on the moldings, door flanges, etc. Anyone owning a camper, needs to have a no. 2 driver of sorts in the camper tool box or else.
JBarca
Nomad II
Nomad II
BFL13 wrote:
Good job on the furnace!
Never heard of those called "square drive" before. Weird! 🙂
Looking it up, found this explanation;
https://www.popularwoodworking.com/questions-and-answers/q-a-square-drive-vs-phillips-head-screws/
Thanks for the good words on the furnace.
The square drive, yeh, it is the same as the Robertson. The Robertson drive originated in Canada and most likely why it is common language there still today.
Here in the US, square drive is common. Here is one of the fastener supply places I buy all my screws from when restoring campers. They sell the bits too, https://www.albanycountyfasteners.com/square-drive-power-bits/1050-600.htm
This is sort of like the term "Vise Grips". They were the first and as time went on and patents ran out, the name Vise Grips is still used by the trades even if they are some other brand of locking pliers... Old names, die hard. Sort of like a Crescent wrench, or other form of adjustable wrench.
John
BFL13
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
dougrainer
Are you serious? Square Drives/screws have been utilized in the RV industry for over 50 years. The actual Square drive bit I use for that limit switch is No 1. Doug
BFL13
Photo in Profile
