โMay-24-2017 01:30 PM
โJun-21-2017 11:01 PM
โJun-21-2017 04:41 PM
โJun-21-2017 03:06 PM
โJun-21-2017 02:38 PM
fj12ryder wrote:dougrainer wrote:Maybe your definition of "Licensed" and mine differ, but to legally do electrical work for someone in Missouri, you have be licensed in Missouri. There is no statewide licensing but you have to be licensed in the area where you are working.
Licensed Electricians on staff? HOW many residential/commercial electrical work is actually looked at by the Licensed Electrician? I doubt the Licensed Electrician will go behind EVERY receptacle that is installed by his crew and verifies that it is done correctly. Now, I find your claim suspect. Why? because how many people take pics of outlets and just happen to state that I had a previous other brand with the same problem? I took pics? Now, to claim that because you have seen a few, the ENTIRE industry is suspect????????? Sorry, you are just bring up a non issue. Doug
"Now, I find your claim suspect." If you're mistaken about this where else have you erred?
"Tens of thousands"? That could work out to 5 units a day, 7 days a week, 52 weeks a year, for 20 years. Would that fall under the heading of "Exaggeration for effect"? ๐
โJun-21-2017 10:24 AM
Lynnmor wrote:
...This thread went from using the type of wire connection to retention force. Pushing a wire into a slot and hoping that the slot doesn't widen or distort too much is not a product I care to use. The majority of my working life was in the connector industry and have built, developed and maintained the dies that produce those slots. All I can say is good luck using them with high loads.
โMay-26-2017 06:21 PM
fpresto wrote:myredracer wrote:
I removed a receptacle in our KZ Spree TT
What was KZ's reply when you brought the issue to their attention?
โMay-26-2017 05:43 PM
โMay-26-2017 03:03 PM
โMay-26-2017 02:29 PM
โMay-26-2017 01:16 PM
โMay-26-2017 01:06 PM
myredracer wrote:Horizon170 wrote:Lynnmor wrote:
I replaced the cheap junk self contained outlets with real residential outlets in a box. The idea that electricians and inspectors are part of the process is not the reality in the RV business.
I have searched and searched and can not find any U.S.A. made duplex.
I did find a couple of good made in USA used at a thrift store.
May someday we can find new ones made in the USA.
That could be true at the retail/residential level. I would try an electrical wholesaler - where the contractors buy "the good stuff". I've often avoided retail electrical items as sometimes you get what you pay for. Some receptacles are made in the US like in the photo. I have never heard of Trademaster - sounds like a name the Chinese would use (like Chicago Electric, eg., lol). For US made recepts. I would look for Hubbell, Cooper, P&S, etc. which probably means going to "spec. grade."
THE most important thing to know is that any device that carries a UL or CSA marking has gone through a long, detailed and rigorous set of tests in order to become certified and legally able to carry the designation and as a result ensures a level of safety to the public. As Mex mentioned, there are a number of grades of receptacles and have the lowest to higher retention force, larger contact surface area and best (lowest) contact resistance with the best being hospital grade. Being US made doesn't necessarily mean better quality in the case or recepts. Recepts. and other wiring devices MUST be UL or CSA certified to be sold & used in the US and Canada.
โMay-26-2017 01:00 PM
Blacklane wrote:
If you're going to install residential outlets in an RV, at least don't use the screws on the side: use the spring-loaded quick connect kind. Vibration can loosen screws, causing huge risk of arc and fire. That's why RV electrical devices have the punch-down connectors and self-contained boxes that are made to hold the wires in-place.
โMay-26-2017 12:49 PM
โMay-26-2017 12:44 PM
