Aug-03-2022 10:11 AM
Aug-04-2022 01:38 PM
C Schomer wrote:
OP indicated they have a grill that uses this..
I know, and that's why I splained the problems for any DIYers. FWIW, the orifice usually comes off and a DIYer can play. I've been gas appliance certified since 78 and I've tried all sorts of things. Sometimes I get my kicks in funny ways!
Aug-04-2022 12:55 PM
Aug-04-2022 05:53 AM
Aug-03-2022 07:04 PM
C Schomer wrote:
pressure.
You can remove the regulator on your grill and connect to the Rv 11” system but then you still need to control the flow/heat . Then you can try a needle valve and it still might not work. Craig
Aug-03-2022 04:21 PM
Aug-03-2022 03:47 PM
Aug-03-2022 03:32 PM
Aug-03-2022 02:40 PM
Aug-03-2022 12:29 PM
jergeod wrote:
Okay I think I have it I need to get a different barbecue that will hook into the low pressure line this barbecue has the high to low regulator and also the temperature adjustment on top of it so I don't believe I'll be able to use this on the camper low pressure line thank you very much
Aug-03-2022 12:06 PM
Aug-03-2022 12:03 PM
Aug-03-2022 11:22 AM
Aug-03-2022 11:10 AM
