Oct-25-2013 09:10 PM
Nov-04-2013 11:53 AM
tvfrfireman wrote:
I charged all four batteries and then disconnected them and let them sit for a few days. They all read the same volts. The two I mentioned that read differently were hooked up to the leveling system while the other two in another compartment were disconnected. The only wire I can find upstream of the battery shutoff switch is two the leveling system. Would those post mounted shutoffs suffice in this situation or should I go with the more expensive wall mounted switches?
Nov-04-2013 11:47 AM
Nov-04-2013 11:35 AM
Oct-29-2013 11:54 AM
Oct-28-2013 10:03 PM
MEXICOWANDERER wrote:
A battery switch must sever all the power, period. 100%. I'll say it again, ONE SINGLE WIRE FROM ALL THE BATTERY'S POST GO TO A SWITCH. The switch cuts off all the power......
Oct-28-2013 09:44 PM
BFL13 wrote:I'd put the two bad one's together, charge them as full as possible on a portable charger, disconnect both from each other, let them sit for a couple of days and check the voltage. They each should be no lower than 6.4V. Anything lower is a problem. Could be those batteries are sulfated and need a recovery. Here's a blurb from MEX on AGM conditioning (recovery):
Too bad that 5.9 one is an AGM. If a Wet, you could use an hydrometer and see what's wrong. No idea what to do with an AGM like that. Some AGM guys will no doubt know...
Trends and tendencies: An AGM battery under conditioning cycle will allow the voltage to rise until it seemingly hits a brick wall, sometimes as low as 14.5 volts. There the voltage stops climbing and this is what you are shooting for. When the voltage resumes its climb a good portion of the occluded plates have been "conditioned" about as well as they're ever going to get. Continue on to 15.5 if voltage is increasing slowly but if voltage is steadily rising quickly, the exercise is over. No sense in jamming unwanted wattage into the battery.
Oct-28-2013 04:41 PM
Oct-28-2013 04:33 PM
DryCamper11 wrote:Dry camper11: Thanks for the help. I went to the trailer this afternoon and checked the batteries. The two on the door side of the trailer that had been disconnected read 6.5 volts each. The other side where they had the wire from the hot side to the hydraulic system that I disconnected yesterday read 6.3 volts and 5.9 volts. They are now all disconnected from each other and I will check them in a few days and see if they lose anymore of their charge. Thanks again. Davidtvfrfireman wrote:
Yes, I have an inverter. I have now separated all the batteries and am going to take them to Les Swab tire center to have them load tested.
If they are 6 volts, be careful. Most tire center employees will never have seen a 6 volt battery, and load testing deep cycle 6 volt isn't the same as load testing starter type SLI 12 volt batteries. If you have checked the voltage of the individual batteries, you will have ruled out or found any bad cells.
If you are simply fighting a discharge problem, start by finding out the current drain first, or just let them sit, disconnected, and watch the voltage. (If you've already done that, sorry for the duplication). Personally, I'd never let a tire center employee anywhere near my deep cycle 6 volts.
Oct-28-2013 12:41 PM
Oct-28-2013 12:34 PM
tenbear wrote:
I should have mentioned, be sure you get one that measures DC current. Less expensive ones may only measure AC current.
Oct-28-2013 12:24 PM
tenbear wrote:You are not embarrassing me in the least. I have a lot of knowledge but just not in this area. One has to start somewhere. Keep embarrassing me all you want. This is how I learn. I am off to the storage lot to try my new found knowledge. Thanks again.. I am grateful.
Probably the first thing to check is the voltage of each of the batteries while disconnected. If one is substantially lower than the others it is probably bad.
If the batteries have been recently charged, within the past day, they will have a higher than normal voltage. It is called surface charge and will leak off within several hours. A fully charged 6v battery should read 6.3v after the surface charge is gone.
If I am embarrassing you with this basic stuff, I apologize.
Oct-28-2013 10:22 AM
Oct-28-2013 10:09 AM
tvfrfireman wrote:tenbear wrote:I will check into this tool. I am pretty sure that the drain must be the hydraulic system as one other person with same brand has the same problem on the DRV forum. The only thing hooked to the battery is the hydraulic system. I don't understand why so many things are wired upstream of the 12 volt cut off switch.. Thanks for you response..
Time to invest in a clamp-on ammeter and see what the drain is.
Oct-28-2013 10:06 AM
tvfrfireman wrote:
I almost forgot, thanks so much for your help. I have a meter and am going to do what testing I can before I take the batteries in. I will have to learn how to use the ammeter function first. Thanks again. David
