The solar controller I installed in the Safari is Bluetooth controlled, and I really like having that function, it replaces a dedicated wired in monitor and control module,
I installed the control app on my tablet,
As. For app updates,, an app designed and dedicated to operating one piece of hardware, comes from the hardware mfg, an once setup and working, is less likely to cause problems than a controller module, and does not need maintaining, backup the app on your Google drive or MS one drive, it will be there if you get a new phone
Yes if my converter had that ability, I would use it
I can explain it to you.
1997 F53 Bounder 36s
