โJul-19-2017 09:32 AM
โJul-20-2017 02:52 PM
SidecarFlip wrote:suprz wrote:pickjare wrote:
Personally, I think the dealership is the best place to take your vehicle for repairs, but you have to find the right one. At 32,000 miles, for $1900 it sounds like they are replacing everything. Ask why??
At 32,000 miles I would expect the front pads to be getting low and the squealer tabs contacting rotors to alert you. The calipers should be ok. Ask why they were quoted? Many companies consider it a liability to reuse things so they replace everything. But service manual won't say it is required. Rotors have a minimum thickness, ask if yours are below minimum. If not, why were they quoted? The rotors should be ok but will need machined as part of front brake pad replacement.
You get what you pay for and brakes are important obviously, as well as having qualified person do the work. My suggestion is to get a second opinion and ask the above questions if price is also $1900. A front brake job (lu be caliper slides, replace pads, machine rotors) should cost less than $500 using good Ford parts. I'm betting rear brakes are still only half worn which is fine for another 30,000.
I agree, and I only contacted the dealer because of the squeaking and to get a quote on a brake job so I can get the $$ ready. The 1900.00 quote was only for the brake pads, all four rotors, and the seals for the rear axles. It doesn't include calipers. (but my aftermarket warranty does cover calipers if they were needed). Sooooo.... This year it looks like I will do a roof re-coat, and a new A/C. And next year brakes
I have to ask... Do you have the Ford extended warranty or a third party warranty? reason I ask is if it's 3rd party, you need to check and see if the Ford garage will honor it.
โJul-20-2017 02:41 PM
โJul-20-2017 12:22 PM
โJul-20-2017 09:57 AM
โJul-20-2017 09:46 AM
โJul-20-2017 02:04 AM
โJul-20-2017 01:55 AM
j-d wrote:
Don't forget now, let me know what its weight was, from Jayco.
โJul-19-2017 09:29 PM
โJul-19-2017 04:14 PM
โJul-19-2017 11:17 AM
j-d wrote:
Are you able to work on brakes, and do you want to? If so, dismantle, scuff pads with emery cloth (or a flat concrete surface) and put it all together lubing it with this
You can get the front Calipers and Pads off easily. To pull the Rotor, you need to remove the Caliper Bracket, 21MM socket and they are TIGHT.
What year is your Chassis? And How many Miles?
Do you have the rear brakes on slide pins like the fronts, or does yours use the stainless steel drive wedges? With either, you can get it apart and do same as front, but drive wedges are a PITA to get back in place.
Remember, unless your Chassis has the "Dump Truck Nose" you can upgrade to those brakes from a 4x4 conversion company.
โJul-19-2017 10:44 AM
โJul-19-2017 10:18 AM
โJul-19-2017 10:16 AM
