โApr-07-2023 10:38 AM
โApr-11-2023 06:48 AM
tessab wrote:
In determining which size wire to use, what load do we enter when calculating voltage drop when adding a 50 amp RV site when the electric service is a 240 volt, 50 amp breaker and RVs technically run on 120 volts? Do we count the RV as 50 amps, or can we count it as just 25 amps since the RV essentially has two 120 volt, 25 amp circuits?
โApr-10-2023 12:31 PM
enblethen wrote:
OP was asking for voltage drop trying what I believe is wire size for a Fifty amp receptacle.
No real need to use anything larger than the normal # 6 wire. It would be good for at least 50 feet then connecting to the 25โ30-foot cord from the rig.
โApr-10-2023 11:07 AM
โApr-08-2023 03:47 PM
Bud
USAF Retired
Pace Arrow
โApr-08-2023 03:25 PM
BB_TX wrote:
Not exactly true. It is theoretically possible to pull 50 amps thru leg 1 while simultaneously pulling anything from zero amps to 50 amps on leg 2. Or vice versa. The neutral current would vary accordingly. In which case one leg would have more voltage drop than the other. And if one leg were pulling zero current, all voltage drop would be on the leg actually pulling current. A completely unbalanced load is as unlikely as a perfectly balanced load. Still, the voltage drop will not likely be equally shared.
โApr-08-2023 01:35 PM
BB_TX wrote:So often that I try to always ask a question first. It saves a lot of typing.2oldman wrote:Happens often.
OP's gone.
โApr-08-2023 12:11 PM
2oldman wrote:
OP's gone.
โApr-08-2023 10:17 AM
2oldman wrote:
OP's gone.
โApr-08-2023 07:34 AM
โApr-08-2023 06:41 AM
time2roll wrote:
The split phase has the advantage of sharing the neutral and reducing voltage drop.
โApr-07-2023 05:53 PM
wa8yxm wrote:
โฆโฆโฆ
Example.. Let's say the run is long enough you calculate 1 volt drop each way.
So your total drop at max load is 2 volts.
But the max drop on EACH leg is 1 volt
NOTE: you will never hit max load.. It just does not happen as it would require PERFECT balanceโฆโฆโฆ.
โApr-07-2023 03:05 PM
Bud
USAF Retired
Pace Arrow
โApr-07-2023 03:02 PM
โApr-07-2023 02:50 PM
