Carrier Bearing Replacement
aljam2
I need to replace carrier bearings on 1999 Holiday Rambler. Called HR and they say they don't have info on part number. Other than taking old ones off, any suggestions on getting the part numbers>
7 REPLIES 7
72cougarxr7
If you have a drive shaft shop in your area, try them. There are a couple shops in my town that do this type of work and sell the carrier bearings much cheaper than the dealers. Fleet Pride is one that comes to mind that I have used, $50 for my carrier bearing vs. over $100 from the dealer, they can press them on for you also.
jwmII
The bearing number should be on the bearings on the cup and cone.
jwmII
RLS7201
Looks like you have a choice of 2 different bearings. You'll need to measure the shaft or bore size to get the correct bearing. As already noted, the carrier bearing is part of the chassis as delivered by Ford.
Rock Auto
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
bucky
I would let the shop doing the work worry about it. That's what they do. Asking the question suggests one shouldn't try this themselves.
Puma 30RKSS
j-d
There should be a tag under one of the mounting or cover bolt heads. And probably info stamped into the passenger side axle tube. Then gOOgle for "Dana Axle Codes." You'll get info and start seeing part suppliers.
RJsfishin
I learned many years ago to not leave for the parts house w/o having the old part w/ you.
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
donn0128
Call the chassis mfg. Probably Ford.
