Champion 3100 Inverter Generator
Kountryguy
I have one of these units, and I love it. My question is, when not in use, should I run the carb dry? I always use fuel stabilizer when running. Thanks for your advice.
11 REPLIES 11
SidecarFlip
bartlettj wrote:
2oldman wrote:
I think I'd check the owner's manual. There's no drain screw?
I have one.
There is a drain screw, as well as a hose, but if you drain it you'll probably spill fuel inside the case and stink up the generator. The owner's manual states to turn off the fuel valve and run it dry if you aren't going to restart it in the same day. It also says for storage, if you aren't going to run it every 30 days, after running it dry put the choke on and pull the starter rope twice to clear the jets, then remove the spark plug and put a bit of oil in the cylinder.
The float bowl on the carb is pretty small, mine will shut down within a minute or two of closing the valve if there's a decent load on the generator.
What I do with mine is I shut off the fuel and run it until it starts to sputter (like it's going to die) and I pull the choke out to get every last drop of fuel from the bowl
Don,t think I've ever put oil in the cylinder however.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
starcraft69
Sandia Man wrote:
If I don't plan on using it for awhile I will run our Champion 3100 dry, this time of year I am out pretty often where I don't bother. We just use the same cheap gas we put in all our vehicles but I always add a bit of Seafoam every time I fill our Champion 3100.
+1
2007 chevy 2500 HD 6.0 longbed
2015 Eagle HT 28.5 5th wheel
tucker the fishing dog
bartlettj
I have one.
Ron3rd
I run a little Seafoam in my Honda and never drain it or run it dry, going on 14 years now
Equilizer Hitch
Honda EU2000
ulvik
I store mine in the winter by draining the tank to get the most out I can then run it till it dies. Then I open the screw at the bottom of the carburetor bowl to drain the remaining fuel out of the bowl. Done this the last 3 years and absolutely no issues.
2018 Ram 3500 DRW
2015 Heartland Big Country 3650RL
Great Smokey Mountains
SidecarFlip
Marine Stabil (blue), not the red, stinky stuff.
RSD559
I also siphon out the tank, before running it dry. I don't turn the fuel off, just let it drain the rest of the tank. Wish there was a drain screw and hose. I've seen too many fuel systems gummed up by modern gas. I use stabilizer in the gas I use for all of my portable gas engines.
2020 Torque T314 Toy Hauler Travel Trailer- 38' tip to tip.
2015 F-350 6.7L Diesel, SRW.
2021 Can Am Defender 6 seater. Barely fits in the toy hauler!
Sandia_Man
If I don't plan on using it for awhile I will run our Champion 3100 dry, this time of year I am out pretty often where I don't bother. We just use the same cheap gas we put in all our vehicles but I always add a bit of Seafoam every time I fill our Champion 3100. Do the same with our Onan except I add Stabil as well since it is fed by a 30 gallon tank where the gas is never emptied.
Our Champion has no issues running our rig's AC unit, ever since we purchased it a couple of seasons ago our 10 year old onboard genny rarely sees action. Already have over 150 hours on our second season of RVing with our Champion 3100, it is a surprisingly hardy unit and with wireless remote start it's even easier to fire up than our Onan.
DiskDoctr
IIRC, while running, turn off the fuel and run until it dies.
Reminds me, I need to add stabilizer and run it dry ๐Ÿ˜‰
2oldman
aguablanco
I have the same unit and I always run mine dry. Still starts on the 1st or 2nd pull every time.
RichH
2017 Ram 1500 EcoDiesel
8 Speed Transmission
2010 Dutchmen 24 FB-SL
Curt 10,000# WDH
Never underestimate the power of stupid people in large groups.
