โFeb-10-2017 04:13 AM
โJul-11-2017 02:10 PM
โJul-10-2017 02:57 PM
D.E.Bishop wrote:
I don't know if they are trying to fool you but try calling SupergenProducts, they are in Newark NY and Glendora CA. The owners are father and son and very easy to deal with. They have the 3400 with a numbers 100222 I believe less than a grand.
โJul-08-2017 10:02 AM
โJul-08-2017 09:41 AM
MrWizard wrote:
Paul Cole 'the father' at Supergen in Azuza Calif, (father and son are both Paul Cole)
is a lot like Randy at Best Converter
they know the product and can tell you the specifics and the differences
and what will work best in your situation
or just help you solve a problem with what you have
example if you have 15k BTU A/C i would recommend the 3400w
but if you have an 11K or even 13k A/C the 3100w will handle it
but a 3400w will give you a little bit more 'breathing space' on those really hot days
also when using LP you loose some power, so a higher power rating provides a few more watts, Lp is nice for home backup, stand by power, because LP does not go bad
but for purchase convenience i like gas, easier to find, and more hours of run time per gal, more energy per gallon
โJul-08-2017 09:36 AM
Roadtech wrote:bg71361 wrote:
I was able to find a post by a Champion Tech; he stated that the 100263 and 100264 are identical except for the 100 watt more conservative rating printed on it. They are the same machines. The 100264 is sold by Cabelas and Camping World as sort of an exclusive item.
Take it for what it's worth, free advice on the interweb.
Good luck!
Sounds like they are fooling the customer into paying more for the same thing.
โJun-19-2017 11:12 AM
โFeb-10-2017 10:58 PM
j.p.f. wrote:
https://www.samsclub.com/sams/4000w-dual-fuel-gen-portable-generator/prod18320286.ip?xid=plp2040-auto:product:1:2
is this it?
$448 at sam's
โFeb-10-2017 05:35 PM
โFeb-10-2017 05:33 PM
โFeb-10-2017 12:32 PM
โFeb-10-2017 10:51 AM
โFeb-10-2017 08:26 AM
โFeb-10-2017 08:06 AM
โFeb-10-2017 08:01 AM
