Apr-12-2023 08:40 AM
May-02-2023 11:32 AM
Boomerweps wrote:Any chance that you monitor the voltage and you see 14.2-14.4 as the low battery gets charged would indicate the existing WFCO is working properly. Mostly WFCO just goes to 13.6 with flooded batteries due to poor design. The 13.6 is fine just a bit slower and may not trigger cell balancing. The solar will complete the charge and allow the balancing at top charge.
While working I discovered the battery is now at 100% charge. It says that on the top mounted display. Just using the basic WFCO converter but I did hook the panels up for about 3 hours the other day. I’m not bothering to change out the converter. I’ll just buy a stand-alone charger for $40 if I later decide I need it.
May-02-2023 10:54 AM
May-02-2023 05:38 AM
Boomerweps wrote:
$246.44 for the WFCO lithium battery conversion part.
I’m holding off for now until we start camping more to make it worth the investment.
I’ll just use the regular converter and top off the battery with the solar panels for now. Invested enough $$ in those. Stormy day today. My plan WAS to use the panels today via the factory solar plug with the 30 amp plug pulled to shut off the converter. That’s FAR easier than on my knees with a flashlight jammed between the fridge and bunk bottom in my TT to find the right breaker. Probably ought to mark it boldly anyways to use the solar panels while camping when Air conditioning means keeping the AC power running.
May-01-2023 09:39 AM
Apr-25-2023 02:55 PM
Apr-22-2023 08:18 AM
Apr-22-2023 08:08 AM
time2roll wrote:Boomerweps wrote:Most OEM converters are better than the so called "lithium" models. Don't spend money until you know what the existing converter is.
Do I need to replace the original converter/charger in my 2019 Wolf Pup 16BHS?
Post the converter model number for best answers.
May as well post the battery information also.
Apr-21-2023 02:18 PM
Apr-21-2023 02:05 PM
Apr-13-2023 06:59 AM
Boomerweps wrote:Initially the existing WFCO will work fine.
WFCO WF-8955PEC
GENERIC LiFePo4 100ah
It appears WFCO sells a lithium converter upgrade kit, checking their website.
Apr-12-2023 05:18 PM
Apr-12-2023 03:23 PM
Apr-12-2023 11:25 AM
