โJan-06-2021 09:34 AM
โJan-16-2021 07:05 AM
โJan-16-2021 07:02 AM
โJan-10-2021 08:07 AM
Land Yachters wrote:If you need to buy a multi meter to read the voltage i extra highly recommend buying a "clamp meter." It allows you to clamp the device around a wire and read how many amps are going through it. I use that feature often it really comes in handy.
Not wishing to highjack this thread, but I have related question and thought it would be better to put in this thread instead of starting new one.
Thanks
โJan-10-2021 07:38 AM
โJan-09-2021 05:44 PM
Land Yachters wrote:Healthy battery should be fine for 30-90 days if truly disconnected and fully charged. Unfortunately it will be up to you to discover if the "disconnect" switch actually disconnects everything, verifying the state of charge before and after, and how they perform after the fact.
Not wishing to highjack this thread, but I have related question and thought it would be better to put in this thread instead of starting new one. Stored my Tiffin for 30 days in Georgia and was very careful to make sure both chassis and house batteries were shut off. Inverter off. Was unable to get any electricity for charging due to storage facility. Coach started right up, but NOTHING worked off house batteries. (4 6v, golf cart batteries). Not even dome light would light. Had to use emergency "jump" from chassis side to get generator going and charge house. Drove straight to campground. Have not checked battery charge since plugged in. 2 questions;
What the hell killed my house batteries? Any idea what could bleed them to death in 30 days?
Will they have useful life for a little while? They are original in coach and probably 2 yrs- 3yrs. old.
Thanks
โJan-09-2021 05:27 PM
โJan-08-2021 10:25 AM
Darklock wrote:
This may be a dumb question, but when on shore power do the lights still work off battery or the 120? I assume battery or inverter.
โJan-08-2021 09:08 AM
โJan-08-2021 08:27 AM
Bud
USAF Retired
Pace Arrow
โJan-08-2021 07:07 AM
โJan-07-2021 04:28 PM
Darklock wrote:Does the water pump turn on? Sounds like the fridge is getting 12v.
Battery has been disconnected since then.
I just went out and checked voltage on battery. Reading on volt meter was 12.3. I reconnected the battery and tried the house lights(LEDs). They would not light. When I pushed the power button for the fridge , its indicator did light up.
โJan-07-2021 02:03 PM
โJan-07-2021 01:21 PM
โJan-07-2021 12:37 PM
Bud
USAF Retired
Pace Arrow
