Converter starts/runs for a few seconds then stops
ivbinconned
Is it because it’s cold here in the frozen Canadian climate?
It’s a WFCO 55 amp.
Ram and 34 ft Cedar Creek
23 REPLIES 23
time2roll
ivbinconned wrote:
It’s a deck mount.
I would look at the 60 amp Boondocker.
http://www.bestconverter.com/12-Volt-Deck-Mount_c_264.html
This should meet the 14.6 volt charging of the battery and for lithium it has a very short absorption time.
BFL13
ivbinconned wrote:
Yes I guess I should have. Normally I do. Guess I am getting lazy.
If I have to replace the converter is there a converter that is compatible with wet as well as Lithium?
And is there any reason to go higher in amperage?
This works with any battery spec, voltage adjustable, perfect for LFP.
60 amps is good for a 100AH LFP above 41F. From freezing to 41F you need a lower amp charger like 15 amps so use a regular car battery charger or whatever till the battery warms up.
https://www.boatandrvaccessories.com/products/powermax-pm3-60lk-12-volts-60-amp-power-converter-batt...
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
ivbinconned
It’s a deck mount.
time2roll
Is the WFCO-55 deck mount or the slide in mounted in the lower section of the electric panel?
I would stay about same size unless you plan to pull new wire for the entire battery charging loop.
ivbinconned
2oldman
If they freeze it's all over. Are you home? Take them out of the coach.
ivbinconned
So I put my smart charger on them to bring them back up.
Plus thetrailer has been plugged for a couple weeks.
ivbinconned
Thanks for the reply Roger.
I checked for voltage at the batteries and they tested 11.5. So it would seem it’s not charging.
Roger10378
Is it the converter that starts and stops or the cooling fan in the converter? The cooling fan is supposed to start and stop as needed to cool the converter. On cold days it will run very little as compared to when it is really working to keep the converter cool.
2005 Cardinal 30TS
2007 Chevy 2500HD D/A
