โApr-14-2020 06:02 PM
โApr-16-2020 04:38 AM
โApr-15-2020 08:40 PM
โApr-15-2020 06:56 PM
โApr-15-2020 07:50 AM
garym114 wrote:I beg to differ. The F53 absolutely uses manifold vacuum to operate the dampers for the air conditioner/heater. There's a small ball vacuum chamber to store the vacuum while the engine is under a heavy load and manifold vacuum isn't available. There's a check valve to prevent the chamber from loosing the vacuum. It could be a broken/cracked vacuum line or bad diaphragm in one of the damper motors. Keep looking for those vacuum lines.
The F53 chassis has no vacuum system. the chassis makers have to add one to operate the heating/ac dash vent system. This system consists of a small 12v vacuum pump and a small vacuum tank and associated vacuum hoses that go to the dash controls.
If there is no vacuum the default vent path is through the defrosters.
Check all these vacuum lines around the pump and tank, usually under the hood in front.
โApr-15-2020 07:46 AM
โApr-15-2020 07:43 AM
wanderingaimlessly wrote:
Not sure with the F53, but with some vehicles low Freon in the AC system will also cause a default to the def and floor. Is the air coming out as cold as you would expect for the AC? If not a recharge may cure the problem.
โApr-15-2020 07:32 AM
โApr-15-2020 06:22 AM
โApr-15-2020 05:37 AM
โApr-14-2020 07:09 PM
โApr-14-2020 06:47 PM
โApr-14-2020 06:05 PM
