โJun-22-2017 07:53 PM
โJun-26-2017 07:43 AM
โJun-26-2017 06:28 AM
โJun-23-2017 06:39 AM
Old-Biscuit wrote:
Sorry but unplugging the leads of thermistor (temp sensing device in food compartment on far right fin) will cause fridge to run/cool continuously----failure mode from lack of temp sensing.
Freezer section 'cold' and food compartment NOT COLD......blockage between freezer evap coil and food compartment evap coil.
Cooling unit is DEAD. NO Good...will NOT cool
โJun-23-2017 06:36 AM
WesternHorizon wrote:
1995 Class C, maybe original fridge. Has worked well but out in the heat and now the fridge won't get cold. Freezer cold.
Found this thread
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/23866404.cfm
OK, I unplugged the thermistor while unit on gas. When I unplug, I hear a thunk and replug hear another. Presumably the gas valve. So does this mean the thermistor is good?
I am running the generator now for AC test as directed in the trhead but it seems like the test above implies the thermistor is good.
Any tips appreciated!
โJun-23-2017 02:34 AM
โJun-22-2017 09:15 PM
