Dry Camping: Many Power Solutions. What about Waste/Water?
otrfun
Lotta discussion and solutions pertaining to solar, generators, huge battery banks, and bulk/boost capable converters keeping everyone powered off the grid.
For those spending more than a weekend dry camping, what kind of creative solutions are available to handle waste and freshwater issues?
42 REPLIES 42
wintersun
Our gray water tank is what fills up first so we do whatever we can to limit the amount of water going down the drains as much as possible. We avoid cooking anything that takes water. By conserving our fresh water supply we are also conserving our gray water tank storage capacity at the same time.
mbopp
otrfun wrote:
For those that use a macerator to pump from the TT to the TV truck bed, what kind/size of auxiliary waste tank do you use?
When you dump the auxiliary waste tank at the dump station using your TV, do you gravity feed or use the macerator again?
I have a surplus ($10) 30-gallon plastic barrel. It's strapped down on a cut-down, inverted pallet (free) for transport.
It's gravity dump at the dump station. I was using an old piece of garden hose but to speed things up the barrel is getting re-worked to a 1-1/2" RV-style dump valve and 1-1/2" hose.
2017 Grand Design Imagine 2650RK
2019 F250 XLT Supercab
Just DW & me......
otrfun
PNW_Steve
X10 On the conservation!
We:
take Navy showers
Never leave water running when brushing death, 4rinsing dishes etc.
Capture dish rinse water for other uses.
Use land based restrooms whenever we can.
Never have water running if at that very moment it is not doing any "work".
I am also in the process of adding auxiliary fresh & waste water tanks in the bed of my TV. I have a macerator pump to move waste into the aux waste tank and a normal RV water pump to transfer fresh water to the trailer.
With this I can make periodic trips to the nearest dump facility without moving the trailer.
I am also plumbing a filtration system between the fresh water transfer pump and the trailer fill.
If I deal that the water source is at all questionable I will fill the aux tank, add bleach, wait 24 hours then pump it through the filter (4 stage, .5 micron & UV) into the trailer tank.
2004.5 Dodge 3500 5.9 Cummins, NV5400, 5" turbo back stainless exhaust, Edger programmer & 22.5 Alcoa's
2002 Forest River 36 5th Wheel (staying home)
1992 Jayco 29 5th Wheel (Mexico veteran & headed back)
2002 "faux" Wanderlodge 40' My new toy....
64thunderbolt
Man you guys work too hard. Just buy a toy hauler with enough tank capacity to stay a week without worry. Just train the women how to take an rv shower instead of a Hollywood 1/2 hr shower.
Glen
04 Tail gator XT 34' 5th wheel garage model
200w solar 2 GC2's 800w inv
Truma tankless WH
99 F350 CC DRW 7.3 ais intake, adrenaline hpop, JW valve body,
cooling mist water inj, DP tunes, 4" exh sys
trucool trans cooler added
2011 RZR 900xp
Hybridhunter
Spare 40 gallon tank in the cab of our truck, and a 12 volt pump to transfer the water. Grey water into the trees (where permitted), and black water is the limiting factor. (Well not really, but I'd rather not deal with it, and far it has not been an issue.)
Pipeman
We just did 10 days dry camping. We probably would have been able to go another few days without filling the black tank. Surprised the heck out of me. Being in the forest allows the male gender to find a potty tree, as the young ones call them. We didn't flush the liquid until the bowl got close to full. We did flush when solids were deposited into the bowl....great conversation....We have a 40 gallon black and 2 40 gallon gray water tanks. We also have a 50 gallon hard, potable water tank that goes in the rear of the truck behind the aux. fuel tank. We also have a 45 gallon collapsible tank in case we are too far from fresh water. Both are pumped with a 12 volt water pump. We have a 5er. We also have a macerator pump and 35 gallon tote. That's our story and I'm sticking to it.
Pipeman
Ontario, Canada
Full Member
35 year Fire Fighter(retired)
VE3PJF
joshuajim
smkettner wrote:
I also added a hot water circulation system. Mostly to keep the pipes from freezing when visiting the snow. And it does help minimize water use by having hot a lot closer to the faucet.
I used an El-Cid 12v pump and a Grundfos valve.
I just let the built-in pump do the work, but then it is just intermittent. The irrigation valve works well for cold water, but I don't know what would happen if it was constantly receiving hot. Beside, the inline valves are only $12 or so.
RVing since 1995.
time2roll
JiminDenver
I guess it is how you look at it. We primitive camped for 20 years before the trailer and the 60 gallons of fresh water we can take up looks like a swimming pool. Two weeks is easy, three weeks possible but we will run out of food. Our first week in the boonies we were so conservative that we only showered every other day and brought most of the water home. We have loosened up considerable and will only bring ten gallons or so home after two weeks.
Most of it is tricks like already listed, but the important thing is never to waste it.
When we run the hot water, a pot collects it until it comes out hot. That water is used for the dishes. Dish water is used for the toilet or to put out the fire at the end of the night.
My shower is a modified sponge bath with a navy rinse and the flow is low enough that the pump pulses. I don't collect shower water for flushing, I just pull a bucket off the grey tank instead.
When we wash the dishes the collected water is heated. We could use the hot water already in the hot water heater to wash and the collected water to rinse but that is wasteful. We start by washing the silverware in a cup with one drop of dawn. The water from that cup is passed to the next until all the cups/glasses are done. The silverware goes back in a cup and rinsed with hot water and that water is passed to the next cup for rinsing and so on until it starts getting sudsy and put in the wash tub. The now hot sudsy water in the tub is used for the plates and lids, those have to be rinsed in the rinse tub and a cup recollects the water until sudsy. By rinsing with hot water and adding it to the wash tub when sudsy, we always have clean rinse water and by the time it comes to pots and pans, there is plenty of hot soapy water to do them with. The last items are rinsed in the rinse tub so that when we dump the wash tub, it can be rinsed too.
One thing about using waste water to flush, I still use a bit of fresh to rinse the grey water down.
We use disposable gloves while cooking so that we don't have to wash our hands every time we touch the food. It's easier to just change gloves.
There are other things that we did while tenting like bagging the toilet or using a spray bottle for washing but we don't have to anymore. That's why we bought the trailer.
2011 GulfStream Amerilite 25BH
2003 Ford Expedition with 435w tilting portable/ TS-MPPT-45
750w solar , TS-MPPT-60 on the trailer
675 Ah bank, Trip-lite 1250fc inverter
Sportsman 2200w inverter generator
joshuajim
We dry camp a lot. The bath is considerable distance from the water heater and a lot of fresh water gets wasted getting the hot there and the grey tank then fills quicker.
What I did was to install a hot water circulating system which returns the cold water in the "hot" line back to the fresh tank.
I installed a tee under the sink hot line and a irrigation control valve with push button at the sink. Ran a line back to the fresh tank. The valves will work on 12v even though they are designed for 24v.
Now when we want to use the shower or sink, hit the button for 5 to 10 seconds and when you turn on the shower/sink, instant hot water and no waste!
RVing since 1995.
time2roll
I rarely sit still for over one week so as long as we are rolling it is time to dump and fill.
And I much rather haul the entire trailer vs dealing with a tote. Did enough of that with the pop-up trailer.
ktmrfs
we have a 30 gallon black and 60 gallon grey. With DW and I that is more than enough for two weeks, the longest we've dry camped w/o passing a dump station.
Even with 2 grandkids, and 4 adults we've gone 6 days with the above setup w/o filling up the grey and black.
Every place we've dry camped has had potable water, so keeping the fresh full hasn't been an issue. I fill 7 gallon blue water jugs at the tap and then have a pump in the pass through along with a dip tube to fill the fresh water when needed.
2011 Keystone Outback 295RE
Gjac
This is a very good question. I always run out of FW before I run out of battery power. What I find is after 7 days I run out of clothes also so I need to do laundry. More specifically my wife runs out of clothes, I have "universal shorts" that I hike, bike, swim and fish in and can go much longer in warm weather. However after 7 days batteries are at 50%SOC, FW is about empty and clothes need to be washed anyways, so we go to a FHU CG with a laundry mat and dump, fill, recharge batteries, wash clothes and bedding. So water and laundry need to be solved before I worry about batteries or solar.
otrfun
SteveAE wrote:
Sure. Install a composting toilet
Checked out the video and googled a few reviews on use of these things in the realworld. Interesting. But, the cost $1000-$2000 and limited space in my TT makes it a no-go. Thanks, though ๐Ÿ™‚
