Dually Valve Kits, Tire Man Ridgecrest or Borg ? ?
dicknellen
I have had it with airing up my 16” dual motor home wheels and I am going to have either Tire Man Dually Valve Kit
( http://www.ridgecrest.ca.us/~tire-man/products.html )
or Duallyvalve Kit
( http://yourtireshopsupply.com/category/796_828/wheel-size-1516 ) installed.
Questions, to Rvers who have these kits installed. What do you have and are you pleased with it?
A possible plus, I have a trip planned to visit family over the holidays in Ridgecrest and could get them installed at the Tire Man there. Or I need to order them and get them installed at a local tire shop here in Fallon. Does anyone have experience with having them installed by Tire Man?
I am not interested in braided valve extensions, had problems with them don’t want them again!
Dick
12 REPLIES 12
dicknellen
John Wayne the Borg is the one to purchase if I ever want to add TPMS. This is what their web site states. TPMS: All of our valve stems in the Dually valve kit can accommodate TPMS Sensor Caps, that go on the end of the valve stem. Dick
John_Wayne
But will the air through caps work if later you want to put on tire pressure sensors.
John & Carol Life members
01 31'Sea View single slide, F53 V-10 with 134,000 miles and counting.
2012 Jeep Liberty Smi brake system
Security by Bentley
God Bless
KF6HCH
IAMICHABOD
j-d wrote:
Those Air-Through Caps are called Gator, Crocodile, V2B, and I think Schrader or Dill also offers them. They are:
Simply the Best
The Hot Setup
The Bees' Knees
Mama's Pajamas
because checking is so easy it's just about fun.
:B
2006 TIOGA 26Q CHEVY 6.0 WORKHORSE VORTEC
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
j-d
Simply the Best
The Hot Setup
The Bees' Knees
Mama's Pajamas
They're "airless" because they don't press the actual valve stem till you push the air gauge or air chuck onto them. Till then, they provide a secondary seal against Air Loss and Dirt Entry.
I can see where if you ran in mud, you'd either have to wipe/brush the tips clean before use - or just use quality metal caps with gaskets instead. That's what Borg used to come with, chrome gasketed caps.
My tire checking time is well under 5 minutes unless the vinyl covers are still on or I go under the bed to check the spare.
Remember, with Tire-Man or Borg valves, tire checking is simply checking. Unless you picked up a puncture, there is no air loss for months at a time. Too bad in a way because checking is so easy it's just about fun.
dicknellen
What is the advantage or disadvantage of Tire Man air thru the caps. I have always been a believer in having good valve caps. Dick
CloudDriver
Tireman extenders installed almost 7 years ago. One of the best things I did for the MH. Really like the air through caps.
I did have to file slots into the rear wheel chrome simulators to get them on and off past the extenders.
2003 Winnebago Minnie 24F - Ford E-450🙂
wd
I have Borg but either are probably good. It's one of the better mods I have made.
EsoxLucius
TireMan. Took me ten minutes this morning to inflate my tires and it only took that long because of the weak compressor at the Kwik Trip air station.
Also talk to Chuck about the proper way to rotating tires on dually vehicles.
2013 LTV Unity MB Theater Seats
635 watts solar panels, 440 AH batteries, BlueSky Solar Boost 3024iL & IPN-Pro Remote, Magnum MS2000 & ME-RC50 remote
Koni Shocks F & R, Hellwig 7254, SumoSprings F & R
2012 Hyundai Accent SE, Blue Ox Aladdin/Patriot
IAMICHABOD
If you are going to be in Ridgecrest I would have Chuck install them, just give him a call, he is a great guy.
If not I would pick his over the Borg ones.
With his you get the original ones that he designed and you get 6 with air thru caps, instead of 4 from Borg with no caps.
I have had mine for awhile and am very pleased with them.
I can check them all in less than 10 min. and it is very easy.
One of the best Mods that I have had done.
j-d
We have Borg. At the time I bought ours, there was a good deal through Six Robbleesbut their price kept going up. Reached a point where Tire-Man looked like the better deal. Borg used to just offer the rear valves while Tire-Man's kit was six valves and air-through caps.
I really don't think there's much difference if any between the actual valves. Pays Yer Money Takes Yer Choice.
The investment is Totally Worth It!
steveownby
The Borg stuff is fine too. Have not had a problem in the three years they have been installed.
Steve Ownby
2003 Monaco Signature
Full-time since 2007
PenMan
I have the Tire Man stems and they work fine. I had them installed by a local shop.
Chris and Jane
2013 Open Range Journeyer JT337RLS
2006 Dodge Ram 3500, 4x4, Crew Cab, DRW, 5.9 turbo diesel
1996 Harley Davidson Electraglide
