โSep-13-2015 06:12 PM
โSep-14-2015 02:53 PM
โSep-14-2015 01:23 PM
magic43 wrote:
Here are pictures of the adapter that I was referring to. Note that both sides of the duplex are tied together and internally connected to the 30 amp RV outlet.
This adapter was originally available from Camping World, but because of the situation that I described above, they removed it. I later bought a couple of them for use on my Honda EU2000's, and noted that they were not available to Canadian customers.
In no way am I slamming or otherwise pointing a negative finger toward anyone or Canada, but just pointing out a situation that I found while trying to use this particular adapter.
I agree that I would never ever plug my RV into any receptacle without first testing it.
โSep-14-2015 01:15 PM
magic43 wrote:Yes, I can see where that thing could ruin your day. I wonder if it was made by an actual, respected electrical component manufacturer or cobbled together by a couple of guys in their garage. It sure looks like a liability lawsuit in an orange plastic case.
โSep-14-2015 01:00 PM
magic43 wrote:
My suggestion would be simple to look at the application that I referred to the the adapter that I pictured. I was never pointing a finger or making an accusation. Had I not personally incurred the situation that I described with the adapter that I referred to then I would have never mentioned it.
We are all here to learn and share our experiences and if they can ever be helpful to anyone, then we all gain in knowledge. The OP asked if there were any differences, and from a practical standpoint there are none as has been pointed out. Having visited all of the Canadian Provinces, my travels here have been quite extensive and enjoyable.
โSep-14-2015 10:47 AM
โSep-14-2015 10:19 AM
magic43 wrote:
Read carefully what I wrote. I never said that there was 240 volts on the outlets.
โSep-14-2015 09:35 AM
โSep-14-2015 08:24 AM
westernrvparkowner wrote:
Even if you came across a split duplex outlet that was wired where each outlet was on a different leg what difference would that make? There is no situation I can think of where it would make any difference since there is no reason to ever cross connect those two outlets.
โSep-14-2015 08:17 AM
tarnold wrote:That's what you need, and a long one, maybe two.
Be sure to carry a heavy extension cord. In most of the PP parks we've stayed in, the power posts are few and far from where you want to set up.
โSep-14-2015 08:11 AM
magic43 wrote:Even if you came across a split duplex outlet that was wired where each outlet was on a different leg what difference would that make? There is no situation I can think of where it would make any difference since there is no reason to ever cross connect those two outlets.
Read carefully what I wrote. I never said that there was 240 volts on the outlets. I did say that the tab is broken and one leg of 240 is connected to each half of the outlet. Each outlet has 120 VAC, but if you read from the hot side of each half, there is 240.
Whether this is a standard wiring practice or just in some campgrounds I do not know. I encountered it in 1995, and as a curiosity, started measuring across the outlets.
Yes, I have traveled/camped in every Canadian Province. I mentioned it only as information and sharing something that I encountered in some Canadian Campgrounds.
โSep-14-2015 07:29 AM
โSep-14-2015 07:00 AM
โSep-14-2015 06:48 AM
โSep-14-2015 06:37 AM
