โNov-07-2016 05:39 PM
โNov-10-2016 09:20 AM
โNov-10-2016 08:04 AM
MEXICOWANDERER wrote:
My fog lamps are above the bumper and they work superb. Celso had a Dodge 6 wheel and the factory fog lights were worthless. When they burned out he pulled them. Then again many folks could care less for function - they want inactive auto jewelery.
โNov-10-2016 07:57 AM
โNov-10-2016 07:47 AM
DarthMuffin wrote:cmeade wrote:
The tradesman trim level has a solid bumper with no cutouts for fog lites. IMHO it would not look as great with add on bolt on fog lites. My factory fog lites look and work great. When I look at Rams without fog lites it looks kind of plain and stripped.
I think I would start looking at junk yards for a bumper with fog lights in it. If every other trim model came with the cutouts it shouldn't be too hard to find. Could even grab wiring harness and switch while there. I'm not up on my Dodge trucks so I can't say if earlier year bumpers are the same, but possible.
โNov-10-2016 05:44 AM
โNov-09-2016 09:43 PM
โNov-09-2016 08:32 PM
โNov-09-2016 06:36 PM
โNov-09-2016 05:28 PM
RoyB wrote:I have been driving pickups for over 40 years and have never had a DOT inspection on one yet. Large commercial trucks yes, but pickups no..I'm not going to worry about it.
Just be sure what you mount is DOT APPROVED which also includes how the added lights come on. You sure don't want any surprises when you go in for a DOT Safety Inspection and have to remove such before passing the safety inspection.
Being a OFF-ROAD Truck and Jeep guy over the years I can say I have been there done that already hehe...
Even the lens are to be DOT Approved as well. It will have a DOT# stamped in the lens area.
Roy Ken
โNov-08-2016 01:21 PM
filthy beast wrote:
Whatever they are called, I use these lights all the time. I figure the more light emanating from the front of the truck, the better I will be seen in marginal situations, or any conditions for that matter.
โNov-08-2016 12:04 PM
landyacht318 wrote:
You looking for supplemental low beams, supplemental high beams or actual fog lights?
Each one has a separate function and beam design.
Actual fog lights are a very wide beam with a very defined cutoff so very little light strays upward and reflects of the water droplets making it harder to see.
most Fog lights that come on New vehicles are just supplemental low beams with no benefit in actual foggy conditions. fashion accessories really.
https://www.amazon.com/Cibie-68716-Cesar-Square-Lamp/dp/B008DQV8D6
http://www.danielsternlighting.com/tech/lights/fog_lamps/fog_lamps.html
https://www.amazon.com/dp/B00K8PE9FY/?tag=2402507-20
โNov-08-2016 08:28 AM
โNov-08-2016 07:22 AM
โNov-07-2016 09:56 PM
