Frozen fresh water tank
DABZ
My fresh water tank froze up. I had a heat gun for 30 mins to valve to empty tank just to open it and found frozen water all the way up. Not sure how far in it is. Any suggestions on unfreezing while RV is outside in freezing weather? I was hoping to unfreeze it to prevent further damage since winter is just starting.
โš Did you read the FTS "Announcement : READ BEFORE POSTING HERE"?
    Forum Technical Support (FTS) is reserved for questions related to the use of the Open Roads Forum sites,
    member profile and photo testing, and for reporting account issues. Please avoid using FTS for RV related
    questions. Instead, select the Sub-Forum which corresponds to the subject of your topic. Thank-you!
    Moved from FORUM TECHNICAL SUPPORT
22 REPLIES 22
2oldman
I guess he's gone. One and only post.
MEXICOWANDERER
My thoughts...
Naples is due west of Miami. If the rig was in Naples, you would read and hear screams...
EVERY FRUIT AND VEGETABLE CROP IN FLORIDA TOTALLY DESTROYED!
The first order is to prevent a disastrous flood when the tank and lines unfreeze. Even if the pipe has to be destroyed the outlet from tank to water pump has to be blocked. The water heater needs to be leak neutered as well.
I do not envy the OP
MrWizard
Moderator
Moderator
coolmom42 wrote:
SidecarFlip wrote:
Mine is an ice cube (half full FW tank) and the unit is inside a marginally heated building. Never have gave it a thought. All the plumbing is evacuated (air purged plus RV antifreeze) and low point drains, drained. Solid frozen FW rank is a non issue in reality.
Only an issue if you think it is....
Or if you need to use it.
Depends on how much water is in there
Near empty?
Near full?
Near full frozen solid, could expand enough to crack the tank
I can explain it to you.
1997 F53 Bounder 36s
Farmboy666
rockhillmanor wrote:
Your sig says Florida. Is that where you are at now? :?
Do you live there or snowbird?
If so we have yet to have freezing temps for more than a 'couple hours in one night' right before dawn. And come morning its back up to the 70's.
The lines will thaw all by itself come this afternoon!:C
I drain the fresh if they predict freeze temps and then just fill it back up if needed.
If it took 30 min with a heat gun to unthaw I doubt he's in Fl.
1320Fastback
They make oil pan heaters for Diesel engines used in cold weather. They aren't much more than about 10"x10" and some are 12V/125v. They don't get hot enough to melt plastic and are self adhesive!
Probably would be enough heat to keep things liquid.
1992 D250 Cummins 5psd
2005 Forest River T26 Toy Hauler
Lwiddis
A severe reprimand is appropriate IMO. Iโ€™ve had a couple.
2oldman
Awaiting the moderator's reprimand post.
Dennis12
Find a warm garage to put it in. Maybe a service station would let you park it in it overnight. Throw him a few bucks.
Dennis Hoppert
coolmom42
Single empty-nester in Middle TN, sometimes with a friend or grandchild on board
SidecarFlip
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
pianotuna
Nomad III
Nomad III
Hi,
Find a radiant heater. One of the ones that glows cherry red. Aim it at the tank. Change of phase from ice to water requires the same amount of energy as raising the temperature of the water from 32 f to boiling. It is going to take many hours to thaw the tank out.
Radiant heaters do not heat the air--they heat the item they are pointed at. Be careful to not melt anything plastic--or cause any item to burn.
The other solution is to move the whole RV into a heated garage.
Regards, Don
SidecarFlip
Frozen FW tank won't hurt a thing. Frozen PEX plumbing lines will...
ksg5000
You will get better advice if you provide a little more info about the accessibility of the water tank.
Kevin
