โNov-18-2013 02:18 PM
โNov-20-2013 02:55 PM
โNov-18-2013 11:33 PM
Old-Biscuit wrote:
The WH having to bleed the lines after sitting all night is NOT normal.
The propane being turned ON at the tank/cylinder would keep line full of propane.
Bleeding the lines should only be necessary if propane has been valved out for an extended period.
Problem in AM......I gotta go with 'enblethen'
โNov-18-2013 07:13 PM
โNov-18-2013 05:16 PM
โNov-18-2013 04:51 PM
Snowman9000 wrote:othertonka wrote:
It is working like it is designed to work. The first time it lit and there was still some air in the line and it went out. now it is designed to try and relight 2 or 3 times more before it locks out and displays the "failed to light" indicator, and you have to turn it off for a few seconds and then turn it back ON so it will retry until it lights or fails to light after 3 more tries. One thing you can do to help eliminate this problem is to light the kitchen stove and let it burn until it burns clean and all the air is expelled, then try and light the water heater. Works for me and as a bonus the refer will also light easier after you expel the air.
Hmmm. Well, it does this every morning. If there is air in the line every morning, that suggests a problem?
โNov-18-2013 04:30 PM
Bud
USAF Retired
Pace Arrow
โNov-18-2013 03:36 PM
โNov-18-2013 03:03 PM
โNov-18-2013 03:01 PM
Bud
USAF Retired
Pace Arrow
โNov-18-2013 02:58 PM
