Generator putting out too much power
swp5767
Hello all! I have an Onan 4.9BFA 4000w gas generator. There is a plug on the cable the way it was sold to me. The PO used this for a race car trailer to power one AC unit and some lights. He said he had no issues.. I would have to say the lights must have been really bright.
Here are some pics of what I have..
Below is the reading while its running.
Here is where the other end of the wire is.
Here is the schematic of the model I have.
What im not sure is, is it hooked up correctly? I tried testing different points on that termimal block and I either got 0 volts or 148 volts. Nothing in between.
Any advice would be helpful.
9 REPLIES 9
swp5767
This is what did the trick. I removed tention from this spring till the voltage came down to 120VAC. With a hefty load on the unit, the power stays steady.
Thanks for all the help!!
Handbasket
SWP, get an Onan service manual (can be ordered online from Onan if nobody's got one). Read up on how your model regulated frequency & voltage, and make sure you adjust with the right screw.
Jim, "What you are experiencing is not a problem. It is an undocumented feature. Thank you for calling Microsoft."
'06 Tiger CX 'C Minus' on a Silverado 2500HD 4x4, 8.1 & Allison (aka 'Loafer's Glory')
swp5767
copeland343 wrote:
If meter is correct you will need to slow rpms down a little. Using the speed adjustment screw maybe a 1/16 of a turn.
There is only one screw to adjust, but when I back it out some, it does not make contact anymore nor does the RPM lower anymore.. I can physically push it till the screw makes contact again and the RPM is lower, but as soon as I let go, it goes back into place.
There must be more to that setting.. I don't see any kind of voltage regulator on this unit.
swp5767
enblethen wrote:
Have you checked the frequency?
Some change voltage and frequecncy as RPMs increase.
The voltage does lower when the RPM's lower. The one thing I cant test is the engine RPM. So I can get it down to 120 range, but the engine seems to be running too slow.
copeland343
swp5767
After some more reading, these older Onans regulate power by engine RPM.
dbbls
I noticed the voltage on the Onan I had was high when there was not a load on it. The load lowered the RPM slightly.
2011 F-350 CC Lariat 4X4 Dually Diesel
2012 Big Country 3450TS 5th Wheel
Hondavalk
Not to ask the obvious but have you verified the meter on a known voltage source.
enblethen
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
