โApr-22-2020 04:55 PM
โApr-26-2020 10:27 AM
happy2rv wrote:
Anyone have any first hand experience with Horst "miracle" probes? They seem to get mostly good reviews on Amazon with a few claiming they are no better than the original probes. I like the idea of the see level sensors, but I'm not sure they are worth the price...
โApr-26-2020 09:40 AM
โApr-26-2020 08:26 AM
โApr-25-2020 01:52 PM
โApr-25-2020 10:01 AM
dougrainer wrote:
Tank sensors DO WORK. BUT, they fail because RV'ers do NOT follow normal procedures to keep the sensors/wall clean. LOTS of Rv'ers do not use Black tank chemical treatment. THAT causes Black tank issues. MORE THAN LOTS do NOT use Gray tank treatment. THAT causes Gray tank issues. Once the metal in the tank probes become coated and the sides of the tank become coated, they will then NOT work correctly. No amount of cleaning will restore or remove that caked on slime on the side of the tanks. The pressure wash usually will get rid of some of the wall slime. The system is simple. You have 4 or 5 probes. 1/3-2/3-full or 1/4-1/2-3/4-full with a single ground probe. When the liquid touches the probes this completes the circuit and turns on the appropriate light on the panel. I ALWAYS ask customers that complain, how come the FRESH system ALWAYS works? Because there is NO dirty water. I have LOTS of full timers that never have a problem because they spend the money and time to treat the 2 tanks from new. It always seems the complaints on these forums always come from newbies that buy used and the previous owners caused the problem. LAST, yes, external sending units like the See Level system is a good way to go to prevent false readings. Doug
โApr-23-2020 06:54 AM
โApr-23-2020 06:07 AM
cavie wrote:
Forget you ever saw them. Non work forever. learn to keep track of your usage. You will sleep better.
โApr-23-2020 05:47 AM
โApr-23-2020 05:31 AM
Planecrazy05 wrote:
Hello everyone,
My wife and I have a fleetwood Bound 2010 35H and our black/gray sensors never show empty. Actually the black tank shows full and the gray flashes 2/3 to full even when the tanks are emptied
โApr-22-2020 09:07 PM
โApr-22-2020 07:31 PM
Dusty R wrote:pauldub wrote:
This is a better sensing system.
X-2
We had an '02 mh. The probes didn't work well on it, and even if they did I figured that measure in thirds wasn't all that great. So looking at the Scan Gauge I see that they give a % reading. So I ordered a set, and installed them. They worked very well.
They are circuit boards that stick to the outside of the tanks.
In 2015 we traded our '01 for a new 2015.
One of the first things I did was put the Scan Gauge system on our new mh.
Dusty
โApr-22-2020 07:25 PM
โApr-22-2020 06:41 PM
โApr-22-2020 06:40 PM
