โMay-11-2019 12:10 PM
โMay-12-2019 10:19 AM
โMay-12-2019 09:41 AM
โMay-12-2019 08:07 AM
wa8yxm wrote:
THis is true but as you can see I "Cut" most of what you posted and just left the most important sentence.
โMay-12-2019 06:54 AM
โMay-12-2019 06:36 AM
cavie wrote:Any response without a quote means it's in response to the op. Otherwise, every single responder would be quoting the OP. That would be entertaining.
When someone responds without a quote it is difficult to know what post they are referring to when the thread goes over one page.
โMay-12-2019 06:32 AM
wnjj wrote:It does, thank you. When you're done you could remove all the quoted op.
Make sense now?
โMay-12-2019 05:31 AM
wa8yxm wrote:wnjj wrote:2oldman wrote:
Please explain to me why the first responder quotes the entire OP.
Because this lame forum software lets you see NONE of the post youโre replying to when responding.
โMay-12-2019 04:48 AM
โMay-11-2019 09:15 PM
โMay-11-2019 04:02 PM
โMay-11-2019 01:41 PM
wnjj wrote:suprz wrote:
I'm installing under counter 12volt LEDs in my camper. The kitchen ones went great... BUT in the bathroom, I am getting confused. There is a single unlighted switch that I wanted to tap into... The problem is that there are 2 wires going to the switch... One loops around with a connector that plugs into the switch, but does not end at the switch, and the other terminates at the switch. I have confirmed that the switch that ends at the switch is a ground because if I tap into that one with the black wire from the LEDs and the other wire to the red from the LEDs, the LEDs light and from what I know is LEDs need correct polarity to work... Now here is what's messing me up, IF the switch I'm tapping into is off the LEDs work, but if the switch is on, the LEDs do not work but the light that is hooked to that switch works normally... I have tapped into both sides of the wire that loops around with the same results... What am I missing. I'm not bothering giving the colors of the wire cause we all know rv makers don't follow color codes
Based upon what youโre describing here is my analysis:
The wire that ends at the switch comes from the light fixture and the other side of that fixture is grounded elsewhere. The โloopedโ wire comes from a 12V fused source. When you connect the LED across the switch, itโs grounding through the unlit light bulb. When you turn on the switch, the wire that ends at the switch is at 12V. Itโs no longer at ground.
You need to hook the red LED wire to the one with the one that ends at the switch and the black to a ground connection somewhere else.
โMay-11-2019 01:27 PM
โMay-11-2019 01:07 PM
โMay-11-2019 12:59 PM
