HF Battery testers
subcamper
I have a bunch of car/truck batteries sitting around in my shop and I want to test them so I can recycle the bad ones and use the good ones for a rare non-electric-hookup 3 day campout with our TT.
I am looking at two Harbor Freight battery testers:
1) Carbon-Pile tester
500A Carbon-Pile Tester
2) Digital Analyzer that uses impedance
Digital Battery Analyzer
Both are pretty inexpensive with the 25% off coupon.
I am looking for suggestions/experiences on which one to buy.
Steve
15 REPLIES 15
pianotuna
Nomad II
Nomad II
Hi,
Replace it with a temperature compensated unit.
subcamper wrote:
I do have a battery hydrometer (with the 4 floating balls) so I can also check that way.
Regards, Don
subcamper
I forgot to mention that there are a couple of deep-discharge batteries also in the mix. These are the ones I want to use on the TT (if they are good)
Later today I am going to HF and buy the carbon pile tester ($40 with coupon) and then charge and test the batteries. I do have a battery hydrometer (with the 4 floating balls) so I can also check that way.
Thanks for all the suggestions. Usually I buy new batteries for our cars and trucks if there is any question, but I have a few golf carts (gas) that I would put a battery in that was not in top condition but they are only driven around the property so no big deal if the battery fails down the road.
Steve
MEXICOWANDERER
Find the CCA of the battery
The LOAD you apply will be one half that.
Test only a fully charged battery
Use a clock or a watch
Load battery for 15 seconds
It must not sag the voltage below nine point six volts
Hold amperage steady meaning twist the dial more if necessary
If amperage then voltage sags on its butt the battery is unrecoverable
If voltage slowly sags below 9.6 volts check cells with a hydrometer
Test Golf car batteries in 12 volt 6 cell series
Load to 200 amps for THIRTY SECONDS. Must remain above 9.6 volts.
Results from a Carbon Pile test trumps anything gotten from an impedance teste but not the other way round.
ksg5000
I own the HF carbon pile tester which I bought many years ago - use it once a year and it seems to work fine but I don't consider myself a battery expert.
Kevin
RJsfishin
Don't buy the HF impedance tester. I bought one a year ago, and it failed miserably the tests I put it thru on known to be weak low voltage batts.
The carbon pile tester works good.
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
Gdetrailer
subcamper wrote:
A few of the batteries are from vehicles that we got rid of and removed the battery. Some of the batteries are only a few years old. Right now I need to weed them out.
Steve
Doesn't matter, really.
You ARE spinning your wheels in the first place.
YOUR "goal" that you stated was to "camp" for THREE DAYS.
To do that with AUTOMOTIVE STARTING BATTERIES you WILL need to drag along at least THREE of them and that most likely will not be enough.
Do yourself a huge favor, SCRAP them by using them as a core towards BETTER SUITED batteries.
Alternately, advertise them on Craigslist for $25 each then put the money towards getting deep cycle batteries..
Yes, you can use a tester, but still in the end you will have batteries designed for a high current draw (starter)for a few seconds then quickly recharged. These types of batteries tend to do a very poor job for lower and longer discharges.. A typical group 24 size starting battery will only have 60ah-70ah of capacity, but using more than 20% of that battery WILL destroy the capacity, especially if that battery sits for three days partially discharged..
I understand the idea of being frugal, but sometimes you have to pony up and get the RIGHT TOOLS FOR THE JOB.
grizzzman
wa8yxm wrote:
I have the carbon pile tester but to be honest neither does a COMPLETE test. both together.. Now that is getting downright close to a Complete test
The Carbon Pile unit though does a good enough job for me It has identified several Sub par batteries over the years.
Ding Ding Ding we have a winner! Both tools have there place.
If I had a choice of one of the other (and not much testing) I would choose the toaster. The real tester should be what others suggest. Specific gravity tester charged voltage tested then a toaster(check that the voltage after the toaster test rebounds quickly)
Good luck with your adventure!
2019 Ford F150 EcoBoost SuperCrew
2016 Rockwood Mini Lite 2504S. TM2030 SC2030
640 Watts Solar. Costco CG2 208 AH and Lifepo4 3P4S 150 AH Hybrid. ElectroDacus. Renolagy DC to DC charger. 2000 Watt Inverter.
Boondocking is my Deal
MEXICOWANDERER
Impedance tester = Handy analysis by algebra
Carbon Pile = Absolute proof analysis by work
Charge old battery until it is both bubbling in the cell and 25 degrees warmer than when you started.
Clean battery posts bright.
Connect cables to battery
Twist load knob to get 250 amps draw.
Voltage needle must stay above nine point six volts for a full 15 seconds.
Amperes must stay at 250 the whole time.
Shut off load
Volt needle must not jump back to 10 volts then slowly rise to 12.
This is a gentle load less than what is applied to a new battery
If the battery fails this test it is a goner.
There is no question a carbon pile load test is more reliable than an impedance measurement. It you want to futz further, a hydrometer can tell you which batteries may benefit from a full equalization.
time2roll
If you really must carry all that dead lead around.... Just charge them (14.4+ volts) for 8 hours. Those that get hot or have excess 'boiling' just recycle. Then let the rest stand resting and disconnected 24 to 48 hours and see what holds 12.6+ volts. Low voltage, leave them at home. Dip them with a hydrometer if you have one.
MrWizard
Moderator
Moderator
i have the carbon pile tester
charge battery to full
then use the Carbon Pile tester for a load test
if it carries the correct load, per the "battery rating"
then capacity is still in the usable zone
I can explain it to you.
1997 F53 Bounder 36s
wa8yxm
pianotuna
Nomad II
Nomad II
subcamper,
Any of the batteries that have sat dead for more than a year can more or less be eliminated.
For the newer ones, charge for 168 hours, wait 24 hours, check specific gravity.
Regards, Don
j-d
Battery testing came up recently on a boater forum. Testers there were all electronic (not carbon pile) from $100 and WAY on up.
In HF, the electronic has the higher ratings.
I think carbon pile can be misused.
That said, the wording of the carbon pile ratings seemed stronger.
So for me, if buying one today: Carbon Pile.
With a warning: NOT down in the bilge of a boat, or where flammable fumes can accumulate. I don't think carbon pile is as "Spark Safe" as electronic.
I have no such tester. Given the choices here, I'd get Carbon Pile but I'd lift the boat batteries out before testing.
subcamper
Steve
