Hot water not flowing through any faucets
jjdsr1
Motorhome faucets throughout discharge good cold water. Trouble I'm trying to resolve is hotwater will not flow through faucets. I have an Atwood water heater that is just 2 yrs old. W/T is working perfectly. Just cannot get hotwater to flow continually throughout the home. There seems to be a restriction. I have flushed the W/H. Pressure relief valve seems to be working fine. Any advise or help? I'm stuck in the "DUHHH" stage! Thanks. Joe D.
9 REPLIES 9
wa8yxm
Second on the outlet check vlave,
If you have a single valve bypass system it is 100% you have such a valve
If you have a multi-valve.. You may still
Seen it before.. The RVer in that case was unable to get the valve off the heater so she (YES SHE!!) reached in with a pair of needle nose pliers and pulled everythign inside the valve out, Gutted it and turned into a pipe.
And she was Back in hot water again.
joebedford
Nomad II
Nomad II
Some water heaters will have THREE knobbies - no check valve.
Old-Biscuit
naturist wrote:
This post, having nothing to do with problems with the forum software, would be more likely to draw useful answers in a more appropriate forum. I notified a moderator to move it.
And in spite of it..OP got answers that applied to issue :W
1492
Moderator
Moderator
โžก Did you miss the FTS Announcement? | READ BEFORE POSTING HERE
    Forum Technical Support (FTS) is reserved for questions related to the use of the Open Roads Forum website,
    member profile and photo testing, and for reporting account issues. Please avoid using FTS for RV related questions.
    Instead, select the sub-forum which corresponds to the subject of your topic.
    Thank-you!
    Moved from FORUM TECHNICAL SUPPORT
cekkk
Of the next 16 posts after the stickies, only ten didn't belong in Forum Technical Support. I'd have guessed 13! :B
'11 Eagle 320RLDS '02 Ford F350 DRW 7.3 PSD
"The world will not be destroyed by those who do evil, but by those who watch and do nothing" - Albert Einstein."
naturist
jerseyjim
IF you have a water heater bypass (kit) for winterization...is that valve open?
Just my 2 cents.........
Beverley_Ken
as Old Biscuit said.
The replacement check valve is probably less than $10.
Ken
2006 Winnebago Outlook 29B E-450.
2012 Honda CR-V AWD
Blue Ox Aventa LX tow bar and Brake Buddy Vantage.
Old-Biscuit
Water Heater HOT outlet (TOP connection) has a 'check valve' ----it has failed
