House batteries and alternator
AllenT1946
Hi all, I need your help. When it comes to electrical issues, I'm not the brightest bulb in the chandalier.I have a '07 monaco and I was told that the house batteries should be charging from the alternator while I'm driving. Mine does not. Is the alternator supposed to charge the house batts or not? If it is, then what could my problem be? If their not, then how can I make them charge that way?
Allen
12 REPLIES 12
MEXICOWANDERER
tenbear wrote:
MEXICOWANDERER wrote:
What is needed is a pictorial page showing what these components LOOK LIKE. Maybe the webmaster would go for creating such a page, maybe not. An image with a description below.
Look for this part
Look for that part
Under the hood. Under the dash. In the battery compartment. But some folks are not aware of basic safety protocol. So this must be considered as well.
That page already exists, its called Google Images.
Hmmm,
Google SOLENOID. GOOGLE IMAGE anything unfamilar. Prepare to go nuts.
truepath
It could be a simple as a tripped breaker. There should be a breaker (or fuse) somewhere in the wire from the battery separator (solenoid or diode isolator) to the house battery. If it is tripped there was something that caused it so that needs to be investigated.
GordonH
I've had problems with engine batteries not charging. Two new alternators installed over two years, better, but the problem happened again in October. Cummins in Brandon MB fixed the problem, I hope. The mechanic thoroughly cleaned all terminals on the alternator plus spent some time cleaning the alternator earth connection. Everything functioned as it should and 1500 miles later an erratic tachometer now functions normally.
tenbear
Look for this part
Look for that part
2010 Subaru Impreza Sedan
CA_Traveler
First check that the chassis battery is charging with your voltmeter, you should read 13.2V+, engine running power plug unpluged. Look for the solenoid by tracing the wires from both battery banks. Check the big terminals with the engine off and power plug out, both should have voltage. Next check the small terminal (one is ground) for voltage with the engine running, power plug out. If you have voltage everywhere then that suggests a bad solenoid.
Both of my Monacos had Intellitec solenoids which failed in about 2 years. None of my Intellitec products seem to be good quality. Both of my Monacos had electronics that activated the solenoid depending upon battery voltage and/or which bank was being charged. Other rigs use the ignition switch to activate the solenoid.
BTW If you have solar disconnect it before checking the above and gen off.
2014 Grand Cherokee Overland
Bob
tenbear
The solenoid in mine looks like this. The 2 large terminals connect to the batteries. The smaller terminals control the solenoid, one is ground and the other is connected to the ignition switch.
Mine is located near the chassis battery and has a 50A fuse in the wire to the chassis battery. Yours could be anywhere???
MEXICOWANDERER
Look for this part
Look for that part
Bobbo
If the chassis battery is charging, I would vote for a bad solenoid. If the chassis battery is not charging, I would vote for a bad alternator.
Bobbo and Lin
pianotuna
Nomad II
Nomad II
Hi,
Start with the chassis owner's manual. Look for references to charging batteries.
My unit came with a 60 amp fuse. After the 2nd time it blew I had it replaced with an auto reset 50 amp circuit breaker.
A year after that the OEM charging solenoid (conveniently located under the chassis battery (grrrrr)) had burned contacts. I had it replaced with a much heavier duty one.
Regards, Don
AllenT1946
I tested my batteries with a volt meter with the engine off and again with the engine running, no difference in voltage. I wouldn't know where to start to track down the problem.
pianotuna
Nomad II
Nomad II
Hi,
The problem may be as simple as a blown fuse, or it may be a solenoid with burned contacts, or a break in the charging wire
Regards, Don
Oasisbob
Your house batteries should charge as you drive. Start your engine and put a volt meter on the battery leads. Your voltage should drop when the motor is turned off. If not there is a problem. Best of luck
Oasis Bob
Wonderful wife 3 of 4 kids at home. 1 proudly serving in USAF
2018 Ford Explorer
2001 Bantam Trail Lite B-19
HAPPY TRAILS:)
