Leave hairline fiberglass cracks alone or no??
Still_Searchin_
We have really small hairline cracks on upper outside corners of 3x11 ft. slide. Ashamed to say I also bumped into a tree with front corner of TT and have 2 small cracks on that front side. I can see the black fiberglass under the gel coat, but just wondering if these cracks do NOT go all the way through the fiberglass, do I need to fix 'em?? Has anyone else ignored small cracks for years & years, and if so, any further damage??
2011 Jayco Eagle Lite 256rks 28ft. travel trailer; Reese SC hitch
2010 Chevy Silverado 2500 6L w/3.73 differential
Member: TTN, Escapees, Good Sam
3x around USA, traveling about 6 mo/year
7 REPLIES 7
sdsdsd
I have several hair line cracks in my boat for yaers, no issues.
steve
The_Falcon
If they are not too spread out, maybe fill them and attach reflectors over the patched area.
Precision Guesses
Joe&Jan 2003 Hurricane 30Q V10
2004 Jeep Liberty, Blue Ox, Brake Buddy
wittmeba
Usually hairline cracks are only in the Gelcoat surface finish. They can be fixed with Gelcoat repair but does not affect the structure - only cosmetic.
Walmart:
http://www.walmart.com/ip/Evercoat-100668-Marine-Match-N-Patch-Gelcoat-Repair-Kit/21784220
Home Depot:
http://www.homedepot.com/p/Aquatic-Gel-Coat-Repair-Kit-35RKWH/100177610#.UnZnRKKc4rg
As indicated if you are seeing fiberglass the problem is deeper than Gelcoat. Should have a fiberglass (boat or car) specialist take a look.
NRA Member & supporter of the 2nd amendment - over 5,000,000 strong
Firefoxยฎ 33
Log home images - Updated 05/19/2013
RVUSA
They call it crazing in the boat world. Smack a sinker into the side of a boat and cracks going every where. Gelcoat is really brittle.
You can try the earlier method, or you can meticulously file the cracks so they are V's and fill them with gelcoat and sand them and buff them and wax them, or you can just fill the cracks with super glue. The super glue flows better than silicone and it's strong when dry.
Golden_HVAC
Hairline cracks where a problem the 1960's and 70's Corvettes had to deal with..
DOn't know what happened to the cracks, but the newer ones do not have that same problem. You might check with a local auto body store, and ask them about the hairline cracks, see what they have to say.
Fred.
Porsche or Country Coach!
Kangen.com Alkaline water
Escapees.com
h2guy
I had some hairline cracks. Rubbed silicone into them hard, waiting till it cured, carefully scraped off the surface coating, applied heavy coat of past wax, let dry, polish off, 7 years ago. Alls good.
Rick & Carolyn
01 Ford SC 4x4 DRW
01 CarriLite 5ver
GENECOP
Hairline cracks......(spider) ok to ignore.....seeing black through the Gelcoat......not ok to ignore...
