โMay-23-2016 01:59 PM
โMay-24-2016 10:34 AM
ralphnjoann wrote:
First, what's so sacred about a brake inspection that it should be done annually?
โMay-24-2016 09:28 AM
Lynnmor wrote:BB_TX wrote:
Have used the EZ Lube system 3 times since new (8 yrs)and brakes still work like new, and no grease on them.
Wasn't that a real mess when you do your annual brake inspection?
โMay-24-2016 09:27 AM
โMay-24-2016 09:05 AM
coolbreeze01 wrote:That's probably not a bad idea considering the problems that some people have had with a brand new trailer. It shouldn't be necessary, and it's really aggravating to think it may be a good idea. When was the last time you pulled the wheels off your brand new car to check for adequate grease? There's no reason that trailer hubs/axles should be any different.FishHaggis wrote:
Typical greasing of the EZLube requires how much grease? Half tube? Quarter tube? Pushed a quarter tube in and nothing coming out. Almost half a tube in another. Can't be that much grease needed? Pile of videos and diagrams out there but not how much grease would be typical.
Hand pack a new trailer's bearings, then you know what you have.
โMay-24-2016 09:02 AM
RCMAN46 wrote:If you grease the EZ Lube for the first time it will take about a half to three quarters of a tube to get the grease through the cavity and out the outside bearing. It really shouldn't since these should come full of grease from the factory, but I suppose it is cost cutting on the part of the factory. I have a triple axle so it took me about 3-4 tubes the first time I did it.fj12ryder wrote:Likes to tow wrote:Yeah, I just pulled my wheels/hubs and they were fine. Do you actually have the EZ Lube system? Or are you just parroting what you've heard?
Are you guys kidding me???? Is this post real???? For those who used several tubes to grease your bearings on an EZ Lube system I know where your grease went!!
Pull the brake drums and look at your brake shoes. EZ Lube axles were primarily designed for boat trailers that get submerged in water. The RV industry picked up on this "easy care-free" idea as a marketing tool. You guys are in serious trouble when you need your brakes!!!!!
How many tubes of grease are required when you grease your EZ Lube?
โMay-24-2016 08:06 AM
โMay-24-2016 07:43 AM
โMay-24-2016 07:23 AM
โMay-24-2016 06:58 AM
โMay-24-2016 06:53 AM
โMay-24-2016 06:47 AM
โMay-24-2016 05:06 AM
โMay-24-2016 04:27 AM
โMay-24-2016 04:23 AM
midnightsadie wrote:
just thinking when all this grease,packed in there nice and snug ,gets warm,where is it going to exband too?
โMay-24-2016 03:55 AM
