โJan-11-2019 11:07 AM
โJan-12-2019 03:07 PM
โJan-12-2019 10:40 AM
ScottG wrote:
While you have the fridge out, look up a tthe vent in the ceiling. If it's just a rectangular hole in an otherwise flat ceiling then your missing out. The effect of fixing it will be greater than insulating because with better flow, it wont have to run as much.
But it's up to you.
Good luck.
โJan-12-2019 09:21 AM
โJan-11-2019 09:44 PM
โJan-11-2019 08:39 PM
โJan-11-2019 07:05 PM
โJan-11-2019 05:54 PM
ScottG wrote:
I've used 1" bat insulation from Home Depot in the past. If you don't have that much room you could use 1/2" rigid foam insulation.
You might also check the installation manual for clearances and how to shape a chimney flue. Doing all of these things makes a huge difference in how the fridge performs, especially in hot weather.
I just spent two days doing all of that on the new TT as I had done to the last one.
A good winter project!
โJan-11-2019 05:34 PM
โJan-11-2019 04:56 PM
โJan-11-2019 03:30 PM
