โApr-28-2016 12:35 AM
โApr-28-2016 01:35 PM
brulaz wrote:Think of it as getting out and firing up a generator to make your DW happy. :h
Just the thought of getting out and firing up a generator to dry my hair makes my skin crawl.
โApr-28-2016 01:30 PM
โApr-28-2016 01:22 PM
brulaz wrote:I feel the same about making a pot of coffee.
โApr-28-2016 01:21 PM
โApr-28-2016 12:59 PM
โApr-28-2016 12:28 PM
Bluebeard wrote:
Ok, thanks for the input. I have a honda 1000w generator and I told her to get a 1000w hair dryer, so maybe the best bet is to just use the generator? Other than the hair dryer, I pretty much don't have a need to cover any heavy loads. We are pretty frugal, other than drying hair.
โApr-28-2016 12:06 PM
Kayteg1 wrote:smkettner wrote:
Ten minutes on the generator-hairdryer and you are done.
Or
Ten minutes on the inverter-hairdryer then an hour of charging to get back to where you were.
Or 10 minutes on inverter-hairdryer and 4 hr on solar charging.
โApr-28-2016 12:02 PM
SoundGuy wrote:
Most hair dryers have several settings so although it may take longer ask your wife to only use the lowest setting. I do and my 1000 watt PSW inverter handles the task without any issues at all running by just one 8 yr old G27 battery. ๐
โApr-28-2016 10:51 AM
โApr-28-2016 10:37 AM
Or
โApr-28-2016 10:21 AM
โApr-28-2016 10:04 AM
SoundGuy wrote:
Well I said it once already but all this talk about high wattage inverters and generators is unnecessary ... a 1000 watt inverter will easily power a hair dryer on it's lowest setting, typically 350 to 500 watts. Just takes a little longer but works just fine ... reserve genset use for recharging the battery.
โApr-28-2016 08:54 AM
โApr-28-2016 08:07 AM
