โJul-27-2015 06:01 PM
โOct-04-2015 10:15 AM
โOct-04-2015 09:46 AM
โOct-04-2015 06:14 AM
โJul-28-2015 01:24 PM
PUCampin wrote:You may need larger jack stands. These adjust from 19" to 30"
The frame is literally 18 inches off the ground, neither jacks nor jack stands are this tall.
โJul-28-2015 01:08 PM
โJul-28-2015 12:41 PM
โJul-28-2015 08:25 AM
smkettner wrote:That's what I have done in the past. I do not like jacking up the trailer and placing it on 4 jack stands.
I jack under the front axel U-Bolt and put on the spare. Then jack under the rear axle U-Bolt and remove the second tire. Leave it on the jack and get two tires mounted. Repeat on the other side and you are done.
โJul-28-2015 07:31 AM
โJul-28-2015 07:16 AM
โJul-28-2015 07:09 AM
โJul-28-2015 04:58 AM
โJul-28-2015 04:36 AM
โJul-27-2015 08:10 PM
RJsfishin wrote:
Its not rocket science. Its hard to do it wrong And its hard to damage anything.
The only time to jack the frame is if the wheel is not removeable by jacking it on the axle,.....fender or plastic shirts.
Anyway, keep a bottle/floor jack on, or close to the u bolts, and you can't miss. Then put a jack stand or blocks also near the u bolts.
Its kinda like, "if it feels good, do it"
edit, be sure to loosen lugs before lifting wheel,......if no impact wrench
โJul-27-2015 08:07 PM
