โOct-16-2019 11:38 AM
โOct-18-2019 07:10 PM
minnow wrote:
Will that Hengs adhere to Eternabond ?
โOct-18-2019 06:41 PM
โOct-18-2019 06:22 PM
ScottG wrote:beemerphile1 wrote:solismaris wrote:
...after 15 years the rubber roof itself is starting to go; the white is wearing off in places and the black shows through....
Purely cosmetic, you don't have to do anything with it.
While the white is cosmetic, it keeps the UV off the black rubber that would otherwise break it down very quickly.
So it is important to keep something over the black part.
โOct-17-2019 09:20 AM
โOct-17-2019 09:05 AM
โOct-17-2019 08:58 AM
โOct-17-2019 07:55 AM
noteven wrote:pianotuna wrote:
EternaBond can be ordered in a roll that is four feet wide.
piano - why do I see the person stuck to the roof like flypaper...? :B
โOct-17-2019 07:35 AM
โOct-16-2019 05:58 PM
โOct-16-2019 03:35 PM
โOct-16-2019 01:44 PM
โOct-16-2019 01:37 PM
agesilaus wrote:X3gbopp wrote:
Clean the roof and coat it with something like Heng's Rubber Roof Coating.
I restored the roof on our 1996 Southwind. After applying Eternabond to the seams and roof edges, it took 2 1/2 gallons of Heng's to coat 30' of roof with two light coats. It's easy to apply and does not need a primer.
Ditto on the Hengs. Probably not a permanent fix but good for several years anyway. I used it on our old fiver, it went on easily after I cleaned the roof. I think I used 2 gallons on a 35 ft fiver and that was for two coats. You get a nice smooth white finish no brush or roller marks.
โOct-16-2019 01:33 PM
