โSep-15-2007 07:12 PM
โFeb-05-2012 02:48 PM
theburren wrote:theburren wrote:C-Leigh Racing wrote:
That three way switch sounds good.
One 12V hot wire with a jumper wire hooked to the other switch side & then two wires from each switch side, then all four wires running from the switch to the motor connector plug end converted down to two wires.
Walla, overide switch doing away with that crazy control box & D/H will get a little recongnition boost from on looking thinking hes opening the door like a gentelman & helping D/W out of the M/H.
Neil
Hmmm. I'd like a manual switch too, actually...
sadly, I'm having trouble understanding completely what you recommended--
Is there a "How to convert your Kwikee steps to Manual using a 3 way switch for Dummies" version?
Very polite thread--
Lots of help and advice:)
โFeb-04-2012 05:27 PM
Neil
โFeb-02-2012 08:16 PM
MopaRV wrote:
Just testing to see if I can post a pic
By rummyron at 2009-11-25
โFeb-02-2012 08:00 PM
Johnny G1 wrote:
I have had to take the motor off to release the steps twice now because they were jammed, seemed over centre for some reason, driving me nuts, have had to replace the crooked arm the second time now because of over pressure and it is brokin again, have reset the step stop bolts so don't know where to go next, other than put a manual switch on and for get about all the automatic stuff, have thought of a 3 way switch, any thoughts would be very much appreiated.
โFeb-02-2012 04:40 PM
Neil
โFeb-02-2012 04:09 PM
โFeb-01-2012 09:53 PM
โFeb-01-2012 12:03 AM
โJan-14-2012 09:03 AM
โJan-14-2012 08:42 AM
โJan-13-2012 01:31 PM
folivier wrote:
I have Kwikee series 32 made in 1993 steps. The large metal gear in the gear housing had a couple broken teeth. I ended up turning the gear so that it uses the other side and it is working for now. \\
I sure would like to find a new METAL gear. I really hate the thought of having to pay so much for the conversion kit from Kwikee that has the plastic gears.
anybody ever found the gear or gear case assembly?
โJan-13-2012 08:04 AM
โOct-31-2011 03:52 PM
โOct-31-2011 03:44 PM
longhauler wrote:
Most likely this is a common commutator style DC motor and the brushes are worn down quite a bit or there is a bad spot on the armature. When Randy taps the motor with a hammer, it is making the brushes in the motor shift and come into contact with the armature or it is causing the armature to shift slightly moving one or more of the brushes off the bad spot. In a lot of cases, motors like these are not setup to be repaired in the field since the cases are sealed o keep out the weather and one has to open them like a can to get to the internals. So a field overhaul is just not possible. One can only swap out the motor as a complete unit like Randy had to. Killer deal on finding the cross over part. I have had to do the same thing with my vette a couple times.
I am sure I will face this same project one day soon as well. I pick up my 95 Destiny M400SI next friday. Drop me a PM about the manual you have. I think I am going to definately need it. Nice write up on the repair, photos, and documentation Randy!
โOct-31-2011 04:29 AM
