โJul-04-2020 08:49 PM
โJul-14-2020 06:33 AM
โJul-13-2020 06:37 PM
โJul-07-2020 01:28 AM
โJul-06-2020 07:28 AM
โJul-06-2020 05:37 AM
pianotuna wrote:valhalla360 wrote:
Marginal info...when it's really hot is when voltage drops raising the amps. I've seen plenty of burnt up 30amp cords from people trying to max out the 30amps.
Do you mean the plugs or the actual cord? I've had several plugs die, but never the actual cord.
I've not had a plug fail/burn since I started using the autoformer. I do limit my demand to 24 amps (but still lost plug ends when I did not autoform)
โJul-05-2020 01:53 PM
theoldwizard1 wrote:pianotuna wrote:
Hemling,
1. Add a double mini split Air Conditioner and replace the existing roof top unit.
Sell the current A/C and just go with the mini-split. You probably need to go with 50A (240V) wiring.
โJul-05-2020 01:47 PM
โJul-05-2020 01:27 PM
pianotuna wrote:
Hemling,
โJul-05-2020 12:00 PM
DownTheAvenue wrote:garyemunson wrote:
The A/Cs are much more efficient now. 2 Will run just fine on 30 amps if you switch the fridge and water heater to gas for the hot part of the day and shut one off if you need to run the microwave. Quite doable if you want to stay comfortable. Put #2 on. You won't regret it!
This is vey good and correct information.
โJul-05-2020 11:44 AM
โJul-05-2020 11:23 AM
โJul-05-2020 09:13 AM
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and two silly poodles.
โJul-05-2020 08:23 AM
โJul-05-2020 08:10 AM
