LED headlight conversion
amxpress
The headlights in my 2007 Dodge 2500 are very poor, especially after driving my daughter's 2016 Toyota with LED headlights. I have aimed them with my 5'er hooked up and my airbags adjusted to keep my TV level. I saw LED H13 bulbs on Amazon reasonabilily priced I am considering. Has anyone tried these LED bulbs? Do you like them?
2021 Toyota Tundra TRD Off Road double cab
2022 Airstream International 27FB
Blue Ox Sway Pro hitch
M.I.L is self quatanting in Jacksonville Zoo
43 REPLIES 43
whatimmadoboutm
Gdetrailer wrote:
GordonThree wrote:
I always curse you guys running hid or led in a reflector style headlights. Very unfriendly move towards your fellow drivers. I don't flash, not worth getting in a headlight pissing contest.
Check a scrapper for the factory projection headlight assembly if you want to join the hid / led club. Alternately retrofit projector lenses can be had for most trucks.
Actually it is not HIDs or LEDs in THOSE folks lights..
Sorry, but you're wrong. I can spot HID/LED retrofits in a halogen reflector housing quite consistently. The weird hot spots and scattered light are a dead giveaway. Although the blue tinted halogens are annoying, cheap HID/LED retrofits are worse.
dangerbird
Before headlights became part of the body lines, New York State required properly adjusted headlights as part of the yearly vehicle inspection. We had alignment devices that suctioned onto the sealed beam headlights. A few moments with a phillips head screwdriver and you were done. I think a lot of the blinding brightness today is due more to improper adjustment than the brighter bulbs. Headlight alignment checks should be an inspection requirement again.
Carl
j-d
Hmm... On the bridge of a ship, or the cockpit of an aircraft, it's all about Preserving the Night Vision. Low lighting, Red lighting...
Then again, the Rules of Nautical Road forbid turning your searchlight onto an approaching vessel. Wouldn't THAT be nice on the highway, if enforced...?
I think that all in all, headlights have improved. Sad part for me is how they yellow and become cataracts. WAIT! Maybe so many of US have Cataracts so we need better headlights.
GordonThree
fj12ryder wrote:
GordonThree wrote:
Turn off that cell phone and GPS screen, dim the interior lights to minimum. When facing on coming traffic divert your gaze to the fog line.
I used to think that until I read an article that recommended against having the interior lights dimmed way down. His rationale was that with the cab at a very low light level your iris will open wider to admit more light. Then when a car approaches your iris is so open that you could be momentarily blinded by the much brighter light. Don't know if it's true, but does make sense. Who knows.
It definitely happens, especially when the oncoming traffic has poorly aimed lights. Once you develop the habit of diverting your gaze, it's not much of a problem. Now and then you'll get blinded by someone's glare, so you fire back with a few 100 watts of off road lights. (Joking)
fj12ryder
Howard and Peggy
"Don't Panic"
landyacht318
GordonThree wrote:
My neighbor's kid is very proud of the 100 watt "15000K" HIDs he put in his beater F250. They're not bluish, they're pure purple. He was bragging about how he got them from e-bay for $25 and claimed they snapped right in.
Seething contempt for the ignorance, arrogance, and sheer narcissism of humanity.....rising.
I hope LEOs start enforcing vehicle lighting laws. First on the chopping blocks would be the blue/purple light queens.
Shame that Auto manufacturers stock headlights are so poor, but a bigger shame that drop in HID and LED replacements are available that allow the placebo effect to allow the purchaser of such light toys think they can actually see better, or that whiter light is somehow brighter.
How many people will ever spend money on something, spend time installing it, and not allow their brains to perceive an improvement?
Humans are so poor at determining how well they can see.
Next time yoy are on an empty street, back away from a sewer hole cover until it is just barely visible in your low beams, then stop. Then turn on your fog lights, and magically it disappears.
GordonThree
They are the cheapo incadescent bulbs which are TINTED BLUE to make their lights LOOK LIKE HIDs!
Those blue tinted bulbs are not DOT approved for ON ROAD USE and often do not have the filament in the correct place to focus the light correctly..
The blue tint adds to the SCATTER of the light making it even worse for the motorist in front or approaching a vehicle with those junk blue tinted cheapo wannabe be "HIDs"..
That's a good theory, it could be part of the problem!
My neighbor's kid is very proud of the 100 watt "15000K" HIDs he put in his beater F250. They're not bluish, they're pure purple. He was bragging about how he got them from e-bay for $25 and claimed they snapped right in. I doubt the power rating, but they're definitely scatter-shot "no aim" type lights, just blasting purple out in every direction.
Gdetrailer
The current crop of LED retrofit lights are hit or miss on getting proper focus AND good ones that do work are not cheap.
Not to mention ALL of those LED conversions are at 6000K color temp, I would consider LEDs IF they made them at a more reasonable 4000K-4500K (that color temp is the range of HIDs not 6000K).
OP should check the voltage at the light bulbs, typically the light ga wiring the vehicle manufacturers use will end up dropping nearly 2V by the time it gets to the bulbs (I HAVE measured this with my vehicles)!
The fix is to add in a headlight relay kit.. A relay kit uses a heavy ga wire that goes directly to the battery.. The result will be about 20% or better brighter lights..
I would skip the LED conversions at this time, they are a "work in progress" and still have a lot of short comings at this time with proper focus, unreliable thermal (heat) management (IE a fan on the back of the light) and electronic "driver" circuits which CAN emit enough RFI that your TPMS and even ABS systems can be affected.
Your money and your time, do with as you wish..
GordonThree
Less light is better more often than not, let your eyes work like they're intended.
Like a previous poster pointed out, if you're having trouble seeing in the dark, consider avoiding night time driving.
MrWizard
Moderator
Moderator
The difference between installing new replacement bulbs
And buying a complete conversion kit with new housings and wiring
And all additional electronics needed
I can explain it to you.
1997 F53 Bounder 36s
doxiemom11
Most people do start having problems seeing when it raining and at night. When that happens, time to try to avoid night driving, not just put bright lights in. This is a normal aging complaint. If you wear glasses, have the anti-glare option put on your lenses. It will help.
westend
bgum wrote:
Just bought a 2017 Jeep with the LED headlights. Big improvement over standard lights. I refuse to believe that a $80 bulb replacement equals a $750 set of lights.
Where does the $750 fit into this?
'03 F-250 4x4 CC
Steeljag
Keep in mind the after market LEDs may not generate enough heat to prevent ice from forming on those head lights ! Volumes on info on the subject on the Jeep Wrangler form !
2018 Forester 3011DS
2010 Flagstaff 26RLS (Sold)
2012 Ford F-150 Screw Ecoboost H/D 3.73
1930 CCC
Going where the weather suits my clothes !
Ozlander
Just because the stealer charges you $750 doesn't mean they cost that much.
Ozlander
06 Yukon XL
2001 Trail-Lite 7253
Ozlander
1995brave wrote:
I got these for my 2012 RAM. I love them.
BPSLighting
BPS Lighting H13 Headlight Conversion LED Bulb Kit Philips LUXEON Zes 8000 Lumens/50W
Got them through Amazon for $80.
They are so nice I ordered 2 more set for our Soul's (same company different model#)
I put some like that on my motorcycle. Work great.
Ozlander
06 Yukon XL
