I think the 65 AMP Blue Sea Systems m-LVD Low Voltage Disconnect that Bend is showing would work just fine for me...
The MAX DC current I ever see is around 53AMPS DC Current when my PD9260C is in BOOST charge mode.
My basic DC current drain is usually around 20-25AMPS when camping off trail for 5-6 hours in a an evening before going to bed after 11PM or so... This is planned for me as I know my battery bank will perform like I want it to and be at its 50% charge state by 8Am the next morning...
I assume this unit has settable 12VDC states. I would want mine to be around 11.9 VDC perhaps... I am also curious if short periods where the battery bank is pulled below these setting would actually trip the system. I would want to have some sort of time delay action as I see my battery bank get pulled down below 11.0VDC on ocassion and then slowly taper back up to the more actually voltage state.
Looks like a great tool to have here... Might look into this setup...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
