LP Regulator
hpdrver
I am replacing the Propane regulator on the motor home and have one question.
The new regulator has in and out ports that seem easy to install but the regulator also has a plastic plug above the vent. What is this plastic part ?
Texas Two Step
2021 Coach House 272XLFR
2020 JL Jeep Wrangler
5 REPLIES 5
pigman1
Just for other interested thread followers, some of the newer 2 stage regulators are coming through with a 1/8" pipe thread plug in the upper area of the second stage area. This is so a fitting can be installed temporarily to check or adjust the actual output of the regulator. We had a regulator fail about 3 weeks ago and the new one was so equipped. When I checked the old one it was only putting out about 7" WC of pressure instead of 11" WC. And yes, I do have a gauge.
Pigman & Piglady
2013 Tiffin Allegro Bus 43' QGP
2011 Chevy Silverado 1500
SMI Air Force One toad brake
Street Atlas USA Plus
hpdrver
It is a Marshall horizontal 2 stage regulator. Cover for adjustment screw makes sense. Thanks
Texas Two Step
enblethen
You should be installing a horizontal two stage regulator and the vent should be facing down.
Plastic cap in most cover the adjustment screw. It should be preset, so don't play with it!
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
wolfe10
Picture or part number will allow better answers.
Could be just a cover over the adjustment screw for calibrating pressure.
And, is your regulator installed VERTICALLY or HORIZONTALLY. Different PN's for each!
Also, why are you replacing a 2017 regulator-- what failed?
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
pigman1
Not sure what regulator you have. Two stage or one? How big is the plug?
Pigman & Piglady
