Lug nuts seized, they have caps!!
raroberts
a little over two years ago I replaced my steel, rusting, trailer wheels with new aluminum wheels. The lug nuts were rusting too, so I bought the good ones (I thought) that were stainless steel. I had a blowout while on a trip and when I tried to take the nuts off one of them was very tight. I put a pipe over my breaker bar to make a long lever and the nut stripped (I thought). After many tries I finally pounded a smaller socket on the nut with a hammer and got the nut off. Upon inspecting the nut I was surprised to realized the nuts had a cap over the nut and it was the cap that was sliding over the nut. I looked at the rest of the nuts and the caps were all loose. I am posting this for you information,,take a look at your lug nuts the next time you take yours off. You do not want to be put in the same situation I was. I think I was very lucky to be able to get that nut off. Get solid nuts.
I do have a question. Does anyone know of a website that has good prices on good nuts? I need 48 of them.
08 F450 4X4 Lariat
07 Stellar 37' 5W Toyhauler
95 XR600R
03 XR400
07 660 Rhino
75 Z1B
27 REPLIES 27
RJsfishin
Yeah, like an owners manual knows everything !!
I have never heard of even one who had nuts come loose from never seize.
Rich
ernie1
Over the years I've used anti seize material on the lugs of my vehicles with absolutely no problems at all. I recently found out that my owners manual for my Toyota Prius says to not use anti seize nor any lubricant on the threads because the nuts may come loose. Now I'm really conflicted about what to do in the future. I think if I don't have any problems with the threads I'll "let sleeping dogs lie". If the threads start to look corroded or give me trouble I'll put a little dab on the offending area.
fj12ryder
Thanks for the link, that was pretty interesting. Of course I especially think so because I agree with his findings. ๐Ÿ™‚ I started using anti-seize for the same reason he did: rusted lug nuts that I almost could not get off. I vowed "Never Again".
Howard and Peggy
"Don't Panic"
drsteve
If you use anti-seize on lug nuts, be sure to NOT apply any under the lug nut where it meets the wheel. An interesting thread on the subject, with links, is here:
2006 Silverado 1500HD Crew Cab 2WD 6.0L 3.73 8600 GVWR
2018 Coachmen Catalina Legacy Edition 223RBS
1991 Palomino Filly PUP
Tachdriver
Careful using anti-sieze and the same torque value: Torque is related to friction and anti-sieze changes the friction
Clicky
fj12ryder
Couldn't have said it better myself.
Howard and Peggy
"Don't Panic"
Shadow_Catcher
The reason I use anti-sieze and correct for using lubrication in torque value.
michael8rc
Does anyone have a good source for excellent lug nuts?
1998 Dodge Club Cab 4x4
2010 Wildwood 292FKDS
hammer21661
Make sure you use a 6 point socket. Mine has them and I used a 12 point a few times then I had to go to a 6 most of them survived with a little help from the hammer.
2018 Ram 3500 SRW crew cab long bed 4x4 diesel Lariamie 1-2018
2013 fuzion 322.8/25/2012
2000 Yellow Lab mix Dog, Earl,The One who gave me Unconditional Love picked up 9-12 or 13, 2001 till 2-7-2014 may he r.i.p.
fj12ryder
I had that happen on a friend's car, and he didn't know they were caps. We had one heck of a time getting them off. Just makes you want to go back to the shop and use that impact gun on some other nuts.
Howard and Peggy
"Don't Panic"
TucsonJim
I used to work in a Goodyear tire shop. Those cheap things would drive us nuts. We found the best way to get them off was to pound a heave duty socket onto them, and rip 'em apart with an impact wrench. Of course, we'd have to get the customer's permission first because they'd have to pay for new lug nuts. When we showed them why, they were usually happy to replace them with solid nuts in case they encountered a flat tire in their journeys.
2016 Ford F350 Turbo Diesel SRW 4x4
2017 Grand Design Reflection 297RSTS
2013 Ford F350 Turbo Diesel SRW 4x4 (Destroyed by fire - 8/29/16)
2014 Grand Design Reflection 337RLS (Destroyed by fire - 8/29/16)
ScottG
They'll go to the ends of the earth to make something cheaply wont they.
Thanks for the heads up.
