โMar-09-2017 05:15 PM
โMar-13-2017 10:36 AM
Byrogie wrote:SoundGuy wrote:Almot wrote:
I think Don asked about 1000W inrush for that Canadian Motomaster aka rebranded Prowatt 1000 that sells for CAD 320, occasionally CAD 120?
Contrary to popular repeated and incorrect opinion the Motomaster branded 1000 watt PSW inverter sold at Canadian Tire for the last several years is not an Xantrex but rather NPower, sold in the US at Northern Tool. This inverter for several years was regularly priced at $299.99 Cdn but would go on sale several times a year in typical Cdn Tire fashion for $199.99, which is what I purchased mine for. Current stock is advertised for $319.99 but typically goes on sale several times a year for ~ $100 less. Those wanting one should grab one next time they go on sale as it looks like NPower is is discontinuing this particular model (the only PSW inverter sold to date by Cdn Tire) and may be replacing it with a larger 1800 watt PSW model which will no doubt be more costly.
This rebranded NPower inverter has two 15 amp receptacles for convenience and I've had no difficulty drawing full rated power from either. If I compare the NPower Owner's Manual to that supplied with my Motomaster branded unit it's virtually a clone. I installed mine for those few times each season we lose campsite shore power, allowing us to use our 750 watt toaster, 550 watt coffee maker, wife's hair dryer (on LOW), a couple of fans, etc, and for this purpose it works just fine despite all the second guessing from those who don't own one themselves and are too quick to judge based on what they don't really know about this inverter. :R No one would claim this is the "best" in a PSW inverter but for those of us here in Canada it represents by far the best deal in a moderately priced PSW inverter of any size. :B
What he said. I have one.
I like the my coffee and toast too.
Seasonal boondocking for 3 years with this inverter and 2x6 volt Trojans.
โMar-13-2017 09:05 AM
โMar-12-2017 12:06 PM
brulaz wrote:
I had a cig plug with built in 3A fuse. The device it supplied went bonkers, didn't blow the fuse but did melt the plug so it ended up disconnected. Added insurance?
โMar-12-2017 11:18 AM
โMar-12-2017 07:49 AM
Almot wrote:
Don, did you blow a fuse in the 400W inverter (with 800W load) or in the cig receptacle?
โMar-12-2017 04:25 AM
โMar-11-2017 11:19 PM
โMar-11-2017 07:31 PM
โMar-11-2017 06:55 PM
โMar-11-2017 06:24 PM
MrWizard wrote:
at what load, how many watts ? what item/device
you don't normally have an inrush on say an electric heating element
but you would on a large fan or say a small compressor fridge
my fridge draws 90>100 running, but has a 900w surge, almost 70 amps
โMar-11-2017 06:22 PM
โMar-11-2017 06:20 PM
โMar-11-2017 06:18 PM
โMar-11-2017 05:33 PM
