โJul-28-2019 04:19 PM
โAug-01-2019 07:07 AM
โJul-31-2019 04:51 PM
myredracer wrote:
On Tremclad, it's made by the same company. Rustoleum is harder to find in Canada and I haven't found the "Professional" grade here anywhere and I buy it the US where it's easy to find in Lowes, etc. I am not sure if Tremclad is formulated exactly the same as Rustoleum but would be surprised if it isn't the same and just re-branded. Either will be good for a TT frame.
If it were me, I'd brush it on to avoid getting overspray on the exterior and parts you don't want paint on, except maybe in visible areas like the A-frame or bumper and you can always mask it off with sheet plastic. You're not going to be showing it at a concourse event and keeping rust at bay is what matters. Nice thing about Tremclad is that if any rust reappears, just sand it down to remove loose rust, clean it and re-paint over it.
โJul-31-2019 03:35 PM
โJul-31-2019 02:38 PM
โJul-31-2019 01:15 PM
โJul-30-2019 01:06 PM
RCMAN46 wrote:LittleBill wrote:
spray the connection with fluid film once everything is repainted. needs to be applied every winter but the stuff works flawless.
also looks like you have a bad weld....
A bad weld on a Lippert frame!!
โJul-30-2019 12:53 PM
โJul-30-2019 12:10 PM
โJul-30-2019 11:47 AM
MEXICOWANDERER wrote:
My opinion?
Pay Attention to what Doug Rainer wrote
Or suffer nightmares of ground loop magic in the future.
90-grit sandpaper.
New self-tapping screw for frame
NEW NEW NEW NEW aluminum lug for the big wire. The old lug has no tin left and it is a guaranteed land mine. Repeat GUARANTEED.
Strip wire insulation so that BRAND NEW PENNY colored copper fits into the lug.
SHINE the frame rail under the new lug to bright steel condition.
Tighten the snot out of the lug screw then the frame screw Go to Wal-Mart and buy a spray can of black Rust-O-Leum BED COATING. The coating will last ten years. No paint can match it for durability.
Doing this repair right is as easy as doing it half-assed. And doing it half-assed will cause problems. Absolutely guaranteed.
On Quicksilver I soldered CAST COPPER LUGS onto the No 1 battery cable then I BRAZED the lug to the steel frame. Back then there was no Rust-O-Leum so I used asphalt-based undercoating.
THIRTY YEARS AGO.
Do it once. Do it right.
โJul-30-2019 10:45 AM
โJul-30-2019 09:19 AM
โJul-30-2019 09:09 AM
bedpan wrote:
I have never seen por15 before so doing some reading on it.. Is it a waste of time to not do the full 3 part system? Or can I just clean up and paint?bgum wrote:
POR 15
โJul-30-2019 08:32 AM
โJul-30-2019 07:42 AM
