New vs old Ford observation.
Gjac
When I started looking at newer MHs (2006-2008) on the Ford Chassis I was amazed at the amount of engine noise in 2 gear do to the higher rpms compared to my old 454. Last week I test drove two 2015 MH's on the Ford Chassis and they seemed much more quiet. My question is what changed? Is there a year that Ford added more sound proofing? I believe the drive train has been the same since 2006.
3 REPLIES 3
Gjac
They were all Class A's the older ones were a Tiffin and a Fleetwood the newer ones were both ACE. Did not like the fit and finish or the slide sticking out 1 inch when closed but it was more quiet than the older models.
Chum_lee
As Golden HVAC says, the Ford F53 chassis you are referring to comes from Ford as a frame, engine/transmission/driveline, suspension, tires/wheels/brakes/axles, steering/instrument cluster, exhaust, and a gas tank. You can drive it, just not at night, and you have to build something to stand/sit on. Wear a helmet or keep your mouth closed otherwise bugs will get in.
Everything else comes from the coach builder.
Chum lee
Golden_HVAC
Ford did not install any sound proofing on the class A motorhomes. That was up to the manufacture.
Class C is another story. It might be that you have a quietier fan on the engine? or more sound proofing on the engine cover.
It might also be that a prior owner installed a Banks or other style of header system on the RV, changing the stock sound.
Fred.
Porsche or Country Coach!
Kangen.com Alkaline water
Escapees.com
