May-05-2018 03:18 PM
May-07-2018 02:57 PM
allredc wrote:
We live in the RV the slides were not moved in or out at the time it stopped working. It was working fine and then just stopped. I followed all the lines they all look good. I disconnected the line in several locations between the bottles and the stove, the flow at all locations was the same.
Not knowing what that should be, you could feel it coming out but it was like really slow like there is no pressure in the line. Not sure how much the regulator adjusts it down.
May-07-2018 01:17 PM
May-07-2018 11:46 AM
allredc wrote:A standard low pressure propane system uses a pressure of 11" WC (water column). That's less than 1/2 psi.
May-07-2018 11:15 AM
May-07-2018 09:29 AM
May-05-2018 08:27 PM
May-05-2018 05:52 PM
May-05-2018 05:18 PM
May-05-2018 05:11 PM
May-05-2018 04:42 PM
May-05-2018 04:22 PM
May-05-2018 04:06 PM
May-05-2018 04:02 PM
May-05-2018 03:54 PM
