No Shore power in Roadtrek
RECTreckin
We are having issues with our shore power working in our 2017 Roadtrek CA Adventurous. We were hooked up and running of it just fine and now nothing. Checked our cords and connections all good. Anyone have any suggestions?
6 REPLIES 6
hotjag1
If it has an inverter, check to see if the breaker on it has tripped.
hotjag1
2003 40' Allegro Bus, 3 slides, 400hp 8.9 liter ISL Cummins
2000 24' Dynamax Isata
smarty
Are you using a surge protector?
LadyRVer
GFI tripped?
cavie
You need a volt meter and need to know how to use it. If you have a dog bone adapter plug it in the plug in a lamp or something to see if you have power there. Check the main 30 amp breaker in the RV. Are you sure EVERYTHING is out or just somethings. You would not be the first to make that blanket statement.
2011 Keystone Sprinter 323BHS. Retired Master Electrician. Retired Building Inspector.
All Motor Homes are RV's. All RV's are not Motor Homes.
Lwiddis
lol. “Downhill!” Brand new RVer won’t know what that means.
Fisherman
Plug something into where you plug in your shore power cord to see if it works. Go downhill from there.
