Norcold 510 help
kjenckes
I have a Norcold 510 refrigerator in my truck camper. The temperature setting won't change from 8. I have the manual and followed the instructions. When you hold the temp setting button it is supposed to change from 1-9 and you let go at the setting you want. Mine stays on 8. Am I missing something or is this a common issue and easy fix? There are no error codes.
1996 Ford F250 Crew Cab 7.3PSD 445,000 miles!
6/1 springs
3400# tires
2005 Lance 820
Solar, Generator, AC
1997 Ranger 487 Bass Boat
Too much stuff to list
1 REPLY 1
Old-Biscuit
Sounds like the Temp Set 'button' has failed in your optical display board
You could pull board, unplug cable harness from power board & clean connection .....but probably need to replace optical board
Part #1....need serial number
