Norcold On Lights Stays On With Frig Off
gkitchens
My Norcold Model N843 refrigerator on light stays on after the refrigerator is turned off. If I push the on/off button, then the refrigerator starts in one of the modes. I am sure the refrigerator is off because I open the door and the light is out. If I turn the master switch for my house batteries off and back on then the on light stays off. Is this something a hard reset would fix?
4 REPLIES 4
gkitchens
Is the board very expensive to replace?
dougrainer
No, a hard reset is ONLY for a NO CO condition, nothing else. You probably have a bad optical board(this is the inside push button display). Doug
1492
Moderator
Moderator
Moved from Forum Technical Support
ScottG
So does my Dometic.
If you have the hidden magnetic switch then you may need to pull a fuse to keep it off.
