โJan-10-2018 09:39 PM
โJan-12-2018 09:07 AM
โJan-11-2018 10:17 PM
red31 wrote:
So to restate the question, is 100 watt panel enough power for some unknown laptaop usage and 2 x unknown watt lights for 4 hrs of use. Assume all lights and laptops are the same. Unknown location, unknown time of year, unknown panel tilt, unknown wiring losses, unknown ...
Sure, give it a try and report back!
โJan-11-2018 10:15 PM
โJan-11-2018 04:36 PM
โJan-11-2018 11:46 AM
TomG2 wrote:
OP: The question is, "Do you want to go camping or become a solar hobbyist?"
I have a friend who travels full time and uses a fifty watt portable unit to replenish his battery between visits to full hookup campgrounds.
On the other hand, some like to diddle with switches and monitor usage and output every few minutes. They will never have "enough" solar or gadgets.
I go with the former.
โJan-11-2018 11:35 AM
โJan-11-2018 11:31 AM
โJan-11-2018 11:24 AM
Seamutt wrote:
Question, if one has two portable solar panels each with its own controller, is it okay to connect each separately to the battery.
โJan-11-2018 11:08 AM
โJan-11-2018 10:55 AM
โJan-11-2018 10:45 AM
ohhell10339 wrote:
Hooking the panels' output directly into the RV batteries with alligator clips or something seems kludgy, but maybe it's the simplest alternative.
2oldman wrote:
It's not recommended as the voltage is too high.
โJan-11-2018 10:42 AM
ohhell10339 wrote:
Hooking the panels' output directly into the RV batteries with alligator clips or something seems kludgy ...
Given that the panel itself is only part of the setup, I would imagine that 200 watts would not cost twice as much as 100 watts, so that might be the way to go.
โJan-11-2018 10:39 AM
ohhell10339 wrote:It's not recommended as the voltage is too high.
โJan-11-2018 09:39 AM
MrWizard wrote:
the typical 100w panel puts out a 5amp charge rate
your laptop probably draws 2-3 amps, then there are the lights
i would recommend 200w
your use may be different, but only you can judge the specfics of the situation
what do you do at night ?
TV/DVDs, PC streaming video, or set with one light and read a book
people often come here and only ask one side of the question
every watt, amphr of power used at night also has to be replaced in the batteries during those solar hours
โJan-11-2018 08:40 AM
